Results 1 to 4 of 4
Thread: Memcal's
    kingy2511's Avatar
    kingy2511 is offline Im in Alan's Wolfpack
    Vs S Commodore Ute
    Dec 2009
    Default Memcal's
    Hey mace.
    I have a 2000 VS Series 3 Ute, i was wondering whether ur Memcals support ur larger throttle bodies?. I was considering doing up my whole intake system (ie: Cold Air Intake, POD Filter, 69mm throttle bodies and corresponding Air flow metre..
    Mar 2008
    Hey kingy2511,
    Thanks for your inquiry
    In regards to you questions, we don have some memcals which support our larger throttle bodies, this isn't one of them though As for running a larger MAF with an off the self/mail order memcal I don't think you'll find one anywhere.
    If you have any other questions please don't hesitate to ask.
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    kingy2511's Avatar
    Vs S Commodore Ute
    Dec 2009
    Thanks for reply..
    Maybe a dumb question, but wat is a MAF?
    Suggestions on wat the best plan of attack is? Will the Memcal work with the CAI minus the throttle body? Or do i have to get it tuned..
    Mar 2008
    Quote Originally Posted by kingy2511 View Post
    Thanks for reply..
    MAF = Mass Airflow Meter
    "Suggestions on wat the best plan of attack is? Will the Memcal work with the CAI minus the throttle body? Or do i have to get it tuned..."
    I suppose it depends on what your budget is. Bank for buck for these motors would be a set of higher ratio rockers. Otherwise I would recommend a manifold insulator or a memcal. The later would still work regardless.
    Memcal is basically the program/tune for which the engine management system uses to run the run/control the engine.
    If you have any more questions please don't hesitate to ask.
    Cheers,
    Steve
    MaceEngineering
  1. ECU's/Memcal's
    By VNCPTR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-07-2008, 10:38 AM
  2. memcal's are here
    By Garth in forum General
    Last Post: 14-09-2004, 07:47 PM
