Results 1 to 6 of 6
Thread: Rockers insulation
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Default Rockers insulation
    Hi, I bought a set of MACE 1:9:1 rockers. I have been searching all over these forums and other forums to find the proper insulation instructions, I read some guy has to keep adjusting his nearly every now and then because they start tapping. (Pretty sure they were not MACE ones)
    Closest I have found to any information is this:
    How to Adjust Chevy Roller Rockers | eHow.com
    You do this with the motor running?
    I understand it could be totally diffrent, as I have also read just put them on and tighten to 15nm and away you go.
    Is there any adjusting or do I just put them on, tighten to correct specs and they are good to go?
    Also is a new timing chain recommended? From what I have read through my searches it adds extra wear on the timing chain and they usually need to be replaced at 150,000km anyway?
    Sorry lots of questions but thanks for the help.
    Best RPG ever
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    On adjustable rocker arms, you may need to adjust them every so often. But the ones in the Ecotec, are non-adjustable, so you just bolt them down and away you go. If you like, or if your worried, you can always check the rocker bolts again for correct tightness a few days after installation, just to make sure everything is perfect.
    And I think its about 15nm and an extra 90 degrees(?), Steve can tell you.
    Ronald Reagan (1986)
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    Trayner's Avatar
    Aug 2008
    2DIE's Avatar
    97 Acclaim
    Feb 2008
    South Aus
    2DIE's Avatar
    97 Acclaim
    Feb 2008
    South Aus
    Pretty simple, just how I thought it would be to start with but when I started looking in to it to double check I found out too much information I didn't need to know :P
    Looks like Ill just need a torque wrench and I'm good to go.
    Best RPG ever
  1. ceiling insulation
    By Garth in forum The Pub
    Last Post: 11-02-2010, 04:09 PM
  2. ceiling insulation - any difference
    By jphanna in forum The Pub
    Last Post: 08-01-2010, 05:05 PM
  3. Heat Proofing/Insulation
    By Morton in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2008, 12:18 PM
  4. bonnet insulation worn, replace?
    By SS57 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-10-2005, 06:22 PM
