Results 1 to 2 of 2
Thread: Installing Mace hub/pulley
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    Default Installing Mace hub/pulley
    I have just installed hub and 10psi pulley. I would just like clarification though - the instructions talk of seating the pulley flush with the end of the supercharger shaft.
    To clarify - is the hub supposed to be flush with the shaft end, or once attached, should the pulley be flush with the shaft end - or is there enough margin that either way (or anywhere in between) is fine?
    "You want fast, reliable and cheap ? You'll find a Commodore out there that can provide any two out of those three!"
    Mar 2008
    Hey Fletch_QLD,
    The hub is suppose to sit flush on the end of the shaft. If you have the pulley sitting flush on the end of the shaft instead the it will still be fine just won't be able to use it as an 8PK belt setup.
    The belt should sit in the middle of the pulley groves (one spare rib on each side with the supplied belt). 1mm either way is not the end of the word as there is an inherent element of give in the belt.
    Hope this helps
    Cheers,
    Steve
    P.S. For problem like this best to give us a call on 1300 GO MACE (1300 466 223) as I'm not always in front of a computer (though I am most of the time)
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  1. [QLD] For sale :Polished Mace 10psi pulley and snout complete suit L67/eaton M90
    By vsl67 in forum Parts And Other Items For Sale
    Last Post: 16-01-2011, 11:39 AM
  2. Installing KnN Pod Filter into Mace CAI system
    By Nayla in forum General Discussion
    Last Post: 13-10-2009, 02:19 PM
  3. [VIC] WTB: SC14 6PSI Pulley & 12Psi Pulley
    By Bz Kn33z in forum Swap / Wanted to Buy / Trade
    Last Post: 20-05-2009, 12:08 AM
  4. Installing Mace air intake manifold insulator
    By EnFoRcEr_001 in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2009, 03:46 PM
