Big congrats to Jim (JET V6) for making 513rwkw![]()
Making only around 420rwkw before and pulling a 9.6 down the quarter with IRS rear end should be good to see what she makes on the track if the drive line can hold up
Here are some more specs about this beast
As for the mods, a big turbo
ENGINE:
STD block
A.R.P studkit
blanced and blue-printed
come racing 4.2 stroker kit
high ratio roller rockers
custom cam
Custom turbo
MACE reverse plenum
MACE 69mm throttle body
MACE 12mm plenum spacer
MACE 12mm manifold insulator
custom turbo manifolds
msd coil packs
EXHAUST:
50mm extrenal wastagte with screamer pipe
3inch turbo back
2 mufflers
AUTO:
trimatic 3speed
3800 TCE stall convertor
transbrake
2 piece tailshaft
DIFF:
santard IRS
L.S.D
3.4:5 diff gears
FUEL SYSTEM:
2 bosch 044's
custom surge tank
custom ruel rails
840cc injectors
STD fuel reg
SUSPENSION:
90/10 fronts
stock rear shockers
TYRES:
front-moroso DS2 front runners
rear- M&H drag slick 9inch by 27 wall
INTERIOR
auto metter boost guage,oil guage,air/fuel ratio guage, rpm and shiftlight guage,
b&m pro ratchet shifter
kenwood mp3 player
OTHER STUFF:
battery relocated to the boot
STD computer
map sensor
4inc intake to turbo
custom air box
custom catch can
Companies involved in the build
MSC performance
Preston autos and diffs
Full Flight Engineering
MACE Engineering
Electronic automotive
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
Here is clip of this beast in auction which is a MUST watch as the car is quite a handful on the track. Who knows how it will go now with the extra power LOL
Steve
MaceEngineering
Wow that back end needs some work to handle the power. 4 link??
yeah ineterested to know how much the bottom end cost?
Awesome work. one tough little V6
Body by Holden, Soul by Brock
the Legend will live forever
That thing is a weapon. Crongratulations to him for such an awesome machine
Holy crap..that things got some grunt, great work lads : )
Also check my ride,sitting on HSV R8 19's
" And on the Seventh day ,GOD created Commodores!!!! "
Mite need to strap that turbo to my ute i think lol
Thanks guys
In regards to the suspension setup his still keeping it IRS at the moment, from my understanding, because he wants the quickest IRS V6. Plus he still drives in on the street and the IRS is handy when negotiating speed humps LOL
Saying this though he'll probably need to upgrade the rear end out of necessity from a reliability perspective, given how hard the power is going to be on the IRS.
In regards to a total build cost, I'm not sure as the build has evolved over a period of time, I'd put the figure at lots all things considered
To replicate that engine, including turbo setup, fueling, tune etc I'd loosely put it at around 20k which would be influenced by the amount of DIY work and mates rates etc.
There is still more in this engine combo, as it's only running 31psi, where it can be running mid to high 30's. I suppose time will tell if it will get pushed that far or not.
Cheers,
Steve
MaceEngineering
Lol i like what one of the camera men said "how the f**k do ya get a 9.82 with that", all over the track, that car is just awesome.
/respect
I saw this dyno sheet yesterday on et street, very impressive from a V6.
Been following it for a while now, I cant wait to see his new times.
what time did that car on the right run? that thing was way ahead
click here to view my ride http://forums.justcommodores.com.au/...02-vy-ute.html
For a V6, this car has the record from my understand, in both IRS and outright V6 commodore. It has factory ported heads.
There is still more in this build as well as it was running less boost then what it was when it was making 420rwkw (33 down to 31psi).
For people interested it will at the LS1 nats this year, hopefully everything holds up for some low 9 runs![]()
MaceEngineering
Man thats one hairy ride, big ups to all involved, to keep it irs and handle more grunt would a piggy back rear swaybar help keep the arse straight when boost hits? It won't really affect the spring rate but should keep the arse end flat and can be unbolted in minutes to drive it home.
RESPECT
Last edited by VNracer34G; 18-04-2011 at 08:07 PM. Reason: respect for the buzzin half dozen
COOK COUNTY PERFORMANCE porting heads/manifolds & blueprinting. tuning by DELCOWIZZID
WANTED SV3800 headers for 34G, need stockers as made by HM headers ~ used with patina prefferable for scrutineering
:0 the size of that turbo :O someone think of the children !!!
MaceEngineering
Update on the beast.
Car was out at Calder last Friday and did a 9.50 @ 142mph
The lower MPH was the fact that a spark plug had failed before mid track causing it to miss and the exhaust manifold had cracked in 3 different areas so it was pretty much was on 5 cylinder from just b4 mid track.
Not bad for a 5 cylinder machine
So clearly a low 9 is on the cards for sure![]()
MaceEngineering
Almost forgot the 60 footer for that run was 1.48 seconds, and was able to drive in a straight line now LOL
Cheers,
Steve
MaceEngineering
wow that would shut up a lot of people saying the v6s are worthless
