Hey guys, Im looking for some advice on what spacer combination is best.
Currently I have a 12mm manifold spacer
The two combinations im thinking are:
-12mm manifold (which I got already) and a 12mm plenum
-or upgrade to JUST a 25mm manifold spacer
And to add to these i will be purchasing a set of roller rockers as well a bit further down the track and I'm a P-plater so if the turtle cover can stay on that would be great
**If it helps the car also has a full exhaust system on it already (extractors back)**
Why does the turtle cover need to stay on? There are no laws that say they cant be off, and if youre worried about popo attention to the spacers, do what HamaTime (i think it was him) and carefully paint the outside of them silver...
The turtle cover doesnt NEED to stay on, i would just prefer it to. It makes everything look a little bit neater aswell
Woah trayner are you seriousthat's a bit extreme ay. On what grounds did they say an engine cover is necessary?
umm yeah thats pretty out there trayner
before this thread turns into a defect discussion could i have some advice and input on the original question please lol
well depends , are you ever going to supercharge your car?
If your going to stay N/A
go
- MACE 25mm Manifold Insulator
- MACE 12mm Plenum Spacer
and other way for supercharged
Yeah mate she will probly stay N/A, got another 2years left on my P's
Might do a L67 conversion afterwards or sell it and buy something new
Was going to ask steve this very question..
The turtle shell can reduce some noise. i removed mine once and went for a drive. bloody louder without if you ask me.
Originally Posted by Yoda
yeah i noticed this but if you look underneath them they have a black material which i believe is there for sound deadening... however it holds the heat in like a bitch tooWas going to ask steve this very question..
i took it off to change leads and spark plugs and havent even thought of putting it back on... some reason id rather look at my engine than bits of plastic with engine sticking out
triple b,
In regards to ideal spacer combo's Trayner has perfectly summed it up well
In your case if you already have a 12mm manifold insulator I wouldn't worry about upgrading to a 25mm item (unless you wanted the best possible gains), instead sticking with the 12mm plenum spacer.
Hope this helps
Cheers,
Steve
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
alrite cheers steve, a 12mm plenum spacer it is and then a little bit further down the track a new set of roller rockers
