Results 1 to 16 of 16
Thread: N/A ecotec mods???
    vs executive
    Feb 2011
    brisbane
    Default N/A ecotec mods???
    just been browsing the mace site and some pretty impressive stuff i was just wondering though i got a stock vs commodore at the moment and if (hypothetically) i were to add all the v6 applicable mods minus turbos superchargers and strokers, such and cams, chips, rollers and all the air intake stuff would that see pretty big gains over stock or just be overkill?
    thanks
    VU Ute 3.8 S
    Mar 2011
    i asked this same question to mace not too long ago and apparently with all the bolt on mods you'll get about 30% more out of your engine or 130-140RWKW
    vs executive
    Feb 2011
    brisbane
    thats not bad then i wanna get them all and do it but itll be a long slow process lol also anyone know how the stroker kit goes on the ecotec? pretty decent?
    thanks
    Mar 2008
    The stroker kit in these work well. The only problem is that they virtually require a full engine build
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    308 vc
    Dec 2010
    North east Adelaide
    as regards "bolt on" i've have pretty much all the mace bolt ons except a different air intake and last dyno comp i was about 30ish kw up on stock v6's and i don't have a tune/chip either.
    Makes for some fun with the rear tyres
    Mar 2008
    Quote Originally Posted by ajvx01 View Post
    Should be interesting to see how she goes once tuned
    MaceEngineering
    308 vc
    Dec 2010
    North east Adelaide
    HSV VT MANTA
    Jan 2010
    308 vc
    Dec 2010
    North east Adelaide
    bolt on means exactly what it sounds like, stuff you can just bolt on and don't need to pull the engine to pieces for.. So rockers yes but no cam.
    Those figures more or less what my current set up makes.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    So you put it on a dyno and didn't bother tuning it??? Why?
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    308 vc
    Dec 2010
    North east Adelaide
    dyno comp mate, did it for giggles really...
    Get's tuned with more mods this month..
    I only used my car as an example of steve's products working in a true bolt on drive off application.
    Mar 2008
    Tuning would help to get even more power and further enhance driveability, however with ecotec bolt on mods they're fine without one, assuming that the engine is in good working order.
    Cheers,
    Steve
    MaceEngineering
    Mk2
    Mk2 is offline
    VX Calais S2
    Oct 2010
    I don't want to spend much on my N/A Ecotec VX but is it worth just getting the spacers and pretty much leaving it at that? All I really want is that little bit of extra kick down low. To give you an idea of what I am working with, everything on my car is stock except wheels and head unit.
    Mar 2008
    Quote Originally Posted by Mk2 View Post
    Given your budget and the gains your after I would highly consider our manifold insulator and plenum spacer (in this order)
    If you have any more questions please don't hesitate to ask.
    Cheers,
    Steve
    MaceEngineering
  15. #15
    Mk2
    Mk2 is offline
    VX Calais S2
    Oct 2010
    Which size of each? I've read bigger on one, smaller on the other for NA and the opposite for forced induction.
  16. #16
    Mar 2008
    An ideal combo for NA would be a 12mm plenum spacer and a 25mm manifold insulator.
    Cheers,
    Steve
    MaceEngineering
  1. Budget Ecotec mods for more bottom end?
    By 2DIE in forum V6 Development And Modification
    Last Post: 29-11-2010, 11:01 AM
  2. VX Ecotec 3.8 L Mods
    By grogadile225 in forum Tuning
    Last Post: 01-10-2009, 07:45 PM
  3. Estimated power of these mods Ecotec
    By -Michael- in forum V6 Development And Modification
    Last Post: 15-01-2009, 08:43 PM
  4. Ecotec mods
    By edb1 in forum General Discussion
    Last Post: 29-05-2008, 08:18 AM
  5. Help need more mods for my ecotec
    By Headpounder in forum V6 Development And Modification
    Last Post: 10-03-2006, 02:38 AM
