Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Z3RO
Thread: cpr6 manifold
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    Default cpr6 manifold
    ok couple of questions ...
    1) do you make these for the sidi sv6 3.6l
    2) how exactly do they work
    3)how hard are they to fit for someone who is reasoably good with cars
    4)will i need to get it tuned
    and also if i put your manifold insulators on my sv6 with extractors etc will i need to get it re tuned again to get the most benefit out of it?
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    MACE don't make the CPR6 Manifold.
    It won't fit the SIDI engine though, it's a different inlet manifold and the SIDI engine sits a lot higher than the old Alloytec, so there is very little clearance between the inlet manifold and the bonnet.
    This website should explain it to you a bit better,
    Alloytec Performance increase Facts and figures, CPR6 Manifold, Performance Manifolds
    Re tune after any mods will bring out more potential.
    Mar 2008
    Ok bad news CPR6 at this time(?) do not have anything to suit SIDI engines. The great news though is that they SIDI inlet manifolds are very good from factory
    Hope this helps
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    SIDI sv6
    Jan 2010
    Penrith
    Mar 2008
    Quote Originally Posted by astroham View Post
    not the answer i wanted ... but thanks
    Sorry astroham, been flat out recently and I didn't read your questions properly
    Unfortunately not
    They mainly work by improving air distribution between cylinders, in addition to flowing more air per given amount of pressure drop
    About as hard as fitting our manifold insulators, so not that hard
    Manifold Insulators - Mace Engineering Group
    Ideally yes, though they still work well as bolt on items
    With the manifold insulators not, with the extractors yes as they may bring up a engine fault code, which would have to be sorted via tune
    If you have any more questions please don't hesitate to ask.
    Cheers,
    Steve
    MaceEngineering
    VE Omega
    Nov 2009
    Here
    Mar 2008
    ^^^ I too feel you pain LOL
    MaceEngineering
    VE Omega
    Nov 2009
    Here
    Hey Steve If I wanted to purchase a CPR6 and the manifold insulators you sell for the VE for price can you give me including postage to 4113 Brisbane? Also no need to bother including the other insulators and stuff I don't need. Also since the bolts are needed are longer than the ones included can you include a set of them in the price too plz.
    Mar 2008
    Quote Originally Posted by Z3RO View Post
    Basically everything that you're after, without the longer bolts (not something that we have) would be $1720 delivered
    Cheers,
    Steve
    MaceEngineering
    VE SV6 A5
    Dec 2008
    Hey guys, I have the same issue with not being able to get the insulators and cpr6 to clear the plastic up the back on my my09, anyone had any experience on removing the plastic bit that is causing all the grief on a non sidi?
    Mar 2008
    Quote Originally Posted by EnFoRcEr_001 View Post
    Dean,
    PM wizeabe, as his run both on his VE from my understanding with success
    http://forums.justcommodores.com.au/member.php?u=39816
    Hope this helps
    Kindest Regards,
    Steve
    MaceEngineering
    VE SV6 A5
    Dec 2008
    Mar 2008
    No probs Dean,
    Please let us know how you go
    Cheers,
    Steve
    MaceEngineering
    WL CAPRICE
    Mar 2011
    Were you able to fit both the insulators and the CPR6 and get clearance for the bonnet to close?
    How many mm were ur insulators?
    Dave.
  1. cpr6 manifold fault??
    By morrow in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-04-2011, 09:52 PM
  2. [Alloytec] CPR6 Manifold. Where to buy and how much?
    By Gunns VC in forum V6 Development And Modification
    Last Post: 21-10-2010, 05:08 PM
  3. cpr6 manifold????
    By MattMarkey in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-04-2010, 02:02 PM
  4. [Alloytec] CPR6 group buy
    By kuzman89 in forum V6 Development And Modification
    Last Post: 29-03-2010, 08:34 AM
  5. VE V6 dyno's over 300 HP with CPR6 Manifold
    By Locky_MAC in forum VE Holden Commodore (2006 - ?)
    Last Post: 01-04-2009, 07:49 PM
