We don't but ASE and these guys do
Automotive Products - Foden Designs
Otherwise you have Elite catch cans as well
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
Body by Holden, Soul by Brock
the Legend will live forever
Ideally it would nice for the trapped oil to drain back into the sump, but I don't think that there is an off they shelf LSX catch can kit around
This aside, they're a very underrated mod!
MaceEngineering
it prevents oil from going back through your intake and will prevent the inside of your engine looking like crap...more resistance etc...i think its a worthwhile thing but only if you got the spare cash laying around
Yeah ive been noticing oil in the plenum of my VY... ive heard this is a common thingIdeally it would nice for the trapped oil to drain back into the sump, but I don't think that there is an off they shelf LSX catch can kit around
might get one of these although i would want it to drain back to sump so might modify things a little eventually
MaceEngineering
Ive got the elitecatch can on my ve and there very good qualtiy and work really well, i reakon it ran smoother since i put on, but eitherway its deff catching all the oil
The problem with the ecotec V6 PCV system is that he PCV valve is a internal part of the intake manifold, to prevent any oil from getting into the intake manifold the internal PCV valve needs to blocked and a external PCV valve added through a 2nd catch can. With the ecotecs you can't simply fit a breather on a rocker cover because of the MAF based engine management system being upset by the un-metered air.
yeah i just cleaned mine out... had about 3-4mm of carbon build up in itIn the case of the VT-VY V6's this is also exacerbated by the exhaust gas recirculation, the build up inside the plenum that is
Also immortality would you be able to point me in the right direction as to how to go about this as i would really like to do it but i was just going to run a catch can from the current breather point on the block through to a catchcan and then connect the breather of the cartchcan up to the throttlebody where it usually goes... is this right or should i be doing it differently?
... you mean to say instead of the hose coming from the PCV valve going directly to the TB like in a stock setup, you add a catch can in between the pcv exit and the TB inlet? If so, this is what i've just done on my L67 and in theory should do the trick.
Hope this helps!
yeah thats what i was trying to say (wasnt very clear was it lol)... sweet ill do that then... you mean to say instead of the hose coming from the PCV valve going directly to the TB like in a stock setup, you add a catch can in between the pcv exit and the TB inlet? If so, this is what i've just done on my L67 and in theory should do the trick.
Hope this helps!
just got confused with people saying the pcv's needed blocking off or something
One of the most underated mods, by many even on here.
Catch Can must be a sealed unit(Not vented) to pass roadworthy.... I used an Elite catch can and reckon it's helped a tad with the economy.
Anyone got a few pictures of a setup on a v6 alloytec?
Dave.
Check out My WL CAPRICE
http://forums.justcommodores.com.au/...price-l-k.html
MaceEngineering
