Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By HamaTime™
Thread: super 6 fuel economy
    holden commodore super 6
    Sep 2011
    delahey
    Default super 6 fuel economy
    I am running 10 psi. Pacemaker extractors hi flow cats 2 1/2 twin into a sports luckey muffler. No cooler. I am only getting 340kms to a tank. Dose this sound right
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by petergl67 View Post
    I'd be happy with that if I were you.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Sep 2011
    delahey
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    I wouldn't settle for anything less than 345.6km's per tank.
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    vt ss v6 supercharged
    Dec 2010
    new zealand
    VS Stato l67
    Mar 2009
    Melb
    I've got pulley, rockers and diff gears and I get comfortably 11.5L/100 (550ks from a tank) and I do a lot of stop start driving every day. Thats from the 70L statesman tank, but you should at least be getting 450ish if you have a 63L tank.
    WH Stato S2
    Apr 2007
    S.E Vic
    I usually get around 400k's out of my stato, usually averages around 14-17 litres per hundred k's depends how i drive.. but thats with it being driven occasionaly and not tuned yet.
    Sep 2011
    delahey
    Thanks. I have only been using it every second to third day and i drive like a grandpa and only still get bad economy. When I drive it a bit harder I only lose 40-50kms. Do u think a Memcal and tune might get me some more ks to the tank
    VX II Calais L67 Manual 17 PSI W2A + MAFLESS
    Apr 2009
    Drive my Calais every day and get around 450-500kms per tank and average around 14.5 L/per 100. City peak hour kills it but its great on the hwy. Thats with every bolt on + tune but with a manual box.
    A new memcal should help fuel economy but depending on if its a generic tune or whether its a mail order (tuned to suit) style will influence what kind of result you will get
    Sep 2011
    delahey
    Yer most of my driving is hwy no traffic as I am on site at 6.30 and finish at 2.30. I think it's drinking to much than it should. I am happy with performance but if I can't achieve more kms I will prob sell it. To expensive to run and I don't drive it much as my mrs drives it with the kids. Need something more fuel efficient
    WH Stato S2
    Apr 2007
    S.E Vic
    Yeh even with the mods and hwy driving you should still probably get more k's.. Might as well ask but have you checked the usual culprits like oxy sensors and even plugs/leads? May be even worth checking to even see if there's build up on them first before replacing as well. I know oxy sensors on mine pretty much took the average fuel consumption down around 1-2 liters per hundred once replaced, and that was when I was still running 10 psi and similar mods to yours.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    What model L67 do you have Pete
    As mentioned already, the O2 sensors are a good possibility. What most people don't tell you is that the O2 sensor is a wearing item and need to be replaced every so often. 100,000-150,000km's is a good time in my book.
    Body by Holden, Soul by Brock
    the Legend will live forever
    Sep 2011
    delahey
    I have a vt series 2 1999 super 6. I think sens might be a prob the engine light comes off and on and might be the prob what do u think
    VS Stato l67
    Mar 2009
    Melb
    If the engine light comes on there should be a fault code stored. Do a search on checking fault codes and that should give you a starting point of things to check/replace
  15. #15
    Mar 2008
    You'll need to sort this out (the electrical fault) as it's likely your main cause for compromised fuel economy
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  16. #16
    Sep 2011
    delahey
    Thanks for ur advise steve good meeting ya. U have time for ur customers and good advice. Will speck to you soon when I install the kit and will need the modular hub and a smaller pulley
  1. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2012, 05:14 PM
  2. High Fuel Pressure - Bad Fuel Economy?
    By Goldie87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2011, 11:23 AM
  3. Recommended Fuel for Vy to increase fuel economy
    By redlion05 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-03-2011, 04:30 PM
  4. Fuel Economy Per Tank Of Fuel
    By HoZy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 08-07-2010, 01:15 PM
  5. Bad fuel economy, strong fuel smell?
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2008, 08:43 PM
