Results 1 to 10 of 10
Thread: wants more boost
    holden commodore super 6
    Sep 2011
    delahey
    Default wants more boost
    Any ideas on how to get more boost. I am looking at getting a yella terra snout. Any good suggestions to achieve more psi
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    Check out MACE's website, he has pulley upgrade kits, that will up your boost, but if you want to go uping the boost, to be safe, add an Intercooler.
    Sep 2011
    delahey
    I am currently running 10 psi just wondering if a yella terra snout will boost it more. I want to go intercooler but in future
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    vyseriesII's Avatar
    vyseriesII is offline The V6 is MACEd
    2004 Vy S Series II
    May 2011
    Sep 2011
    delahey
    Do u think a mini blizzard would be good. I would like to get around the 16 psi mark + if possible. I don't think a medium blizzard kit would fit under bonnet.
    iaydemir's Avatar
    iaydemir is offline Donating Member
    VY V6 Berlina
    May 2009
    Read the Mace product details:
    MINI BLIZZARD INTERCOOLER KIT TO SUIT HOLDEN SUPERCHARGED 6 L67 - Mace Engineering Group
    "The only mods that this car had to achieve these results are as follows.
    MACE mini blizzard intercooler kit
    MACE 1.9 ratio rockers
    MACE 16psi pulley
    MACE Cold air replacement air box kit
    Twin 2 1/2 exhaust cat back exhaust system, no extractors or hi-flow cats!"
    As above, 16psi pulley was used by Mace to test cooler so it should be fine.
    And yes, as it states on Mace's site, you need to modify bonnet & firewall to fit intermidiate/mega blizzard kit as supercharger sites higher.
    Mar 2008
    For ease of fitment, the mini blizzard is the way to go.
    You can run a 16psi pulley, however you'll need a custom tune done (with the mini)
    Otherwise you can run a 13-14psi pulley in conjunction with our mail order tune
    You can install the intermediate blizzard without any body work mods, depending on the car, type of engine mounts and pulley size.
    Can further improve this by running K frame spacers
    If you have any more questions please don't hesitate to ask.
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    Sep 2011
    delahey
    Thanks steve can I install a intermediate kit into a 1999 vt commodore. Would the bonnet close? Thanks mate
    Mar 2008
    Quote Originally Posted by petergl67 View Post
    It can, if you run the smallest pulley. However to absolutely insure that this is the case you can always run K frame spacers
    Cheers,
    Steve
    MaceEngineering
  1. [WA] Wanted: Boost gauge,boost controller, ev6 36lb injectors and walbro in-tank
    By H1GHROLLR in forum Swap / Wanted to Buy / Trade
    Last Post: 11-06-2010, 04:42 PM
  2. How much boost
    By Clint_G in forum V6 Development And Modification
    Last Post: 11-02-2010, 08:06 PM
  3. how much boost?
    By mat vsII in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-12-2009, 09:26 PM
  4. need some boost
    By Mr_Calais in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-03-2008, 08:42 PM
