I think it's a 5/16" unc bolt? 18tpi so the thread pitch is about 1.4mm or (0.056") per turn. so 2 full turns of pre-load would be about 2.8mm or 0.112" pre-load which is to much. Have you checked with Crow to see what the recommended pre-load is to suit there lifters?
From hand tight it's probably another 1/4 - 1/2 turn before the bolt is torqued to spec' so the pre-load would be even more
Body by Holden, Soul by Brock
the Legend will live forever
By hand tight I mean nipping it up with a short handle Allen key. But it 2 turns sounds excessive, i'll have to recheck the exact amount of turns because I wasn't sure what the torque specification is on YT ultralites. Does anyone know?
I have noticed that the engine is now very smooth while cruising. No vibration, idle is much less lumpy, no popping on deceleration. Although top end power seems to have dropped off.
the torque required is based on the fastener, so in this case i think MACE recommends 23Nm for there 5/16" cap screw bolts so the YT items would be much the same
We recommend 23 ft/lbs for the fasteners.
In regards to lifter crush 1.5-2 turns is what we aim for with these street engines.
In saying this though, if you feel that power output has dropped off top end you would have to log how that car is running, as you may be getting more effective lift (changing AFR's) or the valves might not be seating properly at higher RPM.
Regardless though that ticking is likely coming from your extractors, it seems![]()
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
Well as long as 2 turns is not risking bottoming out the lifters i'll just leave it and send the bastard to the exhaust shop. The car has landed on the extractors going over speed humps so maybe there's a crack that they could find.
MaceEngineering
I have heard of someone who set there hydraulic lifters much like solid lifters using adjustable rockers, prevents any lifter collapse but you need to be careful with lifter pump up. Also makes the valve train a little more noisy.
MaceEngineering
I just had a reputable exhaust shop have a listen. He thinks the top end sounds great and the tick is the sound of the gasses in the extractors. He gave me a number of a guy who does ceramic insulation on the inside of the pipes. Apparently it makes a world of difference. If I get that done i'll post back with results.
MaceEngineering
This is different to normal ceramic coating. Some sort of insulation applied to the inside of the pipes apparently. I've never heard of it personally. He also mentioned that internal modifications exacerbate the problem, which sounds logical.
MaceEngineering
