gday, im after a bit more grunt from the old girl without going to forced induction. I was thinking the high ratio rockers and matching cam. what sort of gains could i expect and is there anything else that compliments the rockers and cam? its already got a good intake and extractors.
Hey Flanno,
I would consider start with some bolt ons first such as a larger throttle body and some higher ratio rockers for the job. Going a larger cam certainly help, however may take away a little from the bottom end, depending on the size.
It may not be a problem, however if you do a bit of towing you may notice it.
If you have any other questions please don't hesitate to ask.
Cheers,
Steve
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
what will that do to the air/fuel mixture if i went a larger throttle body? it would need to be tuned im assuming. and iv heard v8 injectors can be installed with a higher pressure fuel pump would that be worth doing?
MaceEngineering
