Hi fellas,
recently purchased the 12mm and 25mm plenum and manifold insulators for my VX, looks good but I'm having trouble taking the captive bolts out of the chamber?!
any helpful advice? I've tried vice grips on one end and turning the bolt out but no joy.
Cheers.
GreenMachine,
You can persevere with what you're doing and it should fine. Otherwise you can cut the head of the bolt they should drop out. Once you've done this then re-tap the holes as it sounds like the thread is damaged (which isn't common)
If you have any more questions please don't hesitate to ask.
Cheers,
Steve
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
If the threads are damaged then cutting them off is the better option as you will do less damage to the threads that way. Try a little CRC or oil (on the threads)first but don't waste to much time if they don't want to go.
Body by Holden, Soul by Brock
the Legend will live forever
Thanks guys! all taken care of, just one bolt was stuffed.
love the huge improvement; I can actually launch from the lights instead of chugging after traffic.![]()
hey thanks for the hoses/clamps Steve, but looks like mine doesn't need them. JUST long enough to fit clean and tight
thinking of getting the 69mm TB![]()
MaceEngineering
