Results 1 to 14 of 14
Thread: VX commodore Mod
    VX Equipe
    Dec 2011
    rockhampton
    Default VX commodore Mod
    This has probably been asked plenty of times in this thread but i was wondering what is the better option to go a CIA either MACE or one of Original parts . com or go MACE Plenum/Manifold spacer with a manifold insulator, best option being more power and better breathing??
    Thanks in advance
    SM1D3Y's Avatar
    SM1D3Y is online now aka Drew
    VX Calais L67
    Jul 2011
    Mar 2008
    Value for money I would go with a manifold insulator first, preferably a 25mm item.
    On the note of CAI kits, our VT-VY V6 kits are the easiest to install on the market.
    If you have any other questions please don't hesitate to ask.
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    VX Equipe
    Dec 2011
    rockhampton
    Ive got supercharged pacemaker extractors, twin 2.5 xforce exhaust and twin high flow cats, not really after saving money i would like to no what is the best direction to go and now im looking at roller rockers what are ur thoughts as to what i should start with and what can i get more power out of as far as fitting i can do it myself with my dad so no problems there and plus MACE you have a very good HOW TO Section anyways =)
    so what im asking is roller rockers by them selves, a CIA by itself or the Plenum and manifold?? as listed above.
    Mar 2008
    Quote Originally Posted by vxcp View Post
    Value for money, if you budget stretches far enough, then a set of rockers would be the go. Second to the rockers would be a manifold insulator to suit.
    Cheers,
    Steve
    MaceEngineering
    VX Equipe
    Dec 2011
    rockhampton
    is there a big difference in the High rollers and Ultra high ones i see that ultra ones comes with pushrods is it worth the money to get ultra or not really?
    VX Equipe
    Dec 2011
    rockhampton
    so i have the choice to get either of these 1:98 MACE Ultra high Ratio Rockers Holden V6 VS-VX Ecotec and Supercharged (L67) | eBay they are the ultras or these HIGH RATIO ROLLER ROCKERS FOR HOLDEN ECOTEC AND L67 V6 | eBay same price 450$. 2 things im concerned about 1. do i need to throw anything else in with the ultras and 2. do u think the ultras are worth it buying them second hand they look alright as far as i can see what u guys think?
    VY Spac l67
    Aug 2008
    if I were you I wouldn't buy the second hand items for the following reasons;
    1) They may be damaged from improper installation or misuse (may not be visible but can cause problems in the long run)
    2) You get a LIFETIME warranty if you buy from MACE
    Do the smart thing
    VX Equipe
    Dec 2011
    rockhampton
    is there much kw difference between the two would the high rollers be okay or would u recommend ultra ones??
    Mar 2008
    vxcp,
    The difference in power gains are shown below for NA setups
    1.9:1 10 to 13rwkW
    1.98:1 13 to 20rwkW
    Cheers,
    Steve
    MaceEngineering
    VX Equipe
    Dec 2011
    rockhampton
    i saw on a thread that MACE only re work the roller rockers is this true im just checking because i was going to buy i set but probs not now however the post was 2008 could be different now =)
    Andrew.
    Mar 2008
    Andrew.
    Andrew,
    The rockers we supply are manufactured items. These are perfectly fine, so much so that we offer a lifetime warranty on them
    Cheers,
    Steve
    MaceEngineering
    VX Equipe
    Dec 2011
    rockhampton
    sent u a pm i might go the more torque root first i got plenty of top end
    Mar 2008
    The manifold insulator and plenum spacer would be the items you would want to consider first then
    You have a PM
    MaceEngineering
  1. [VIC] 1981 VC L Commodore & (year unknown) VC Commodore
    By -vkhg in forum Vehicles For Sale
    Last Post: 05-12-2011, 11:40 AM
  2. [VIC] FE2 Suspension setup for VE commodore @ Ultra low King Springs for VE commodore
    By IGNITIONSV6 in forum Parts And Other Items For Sale
    Last Post: 05-09-2010, 02:39 PM
  3. will a vx commodore ecu work in a vt commodore
    By lestat2220 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2010, 10:05 PM
  4. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
