Hey mace, I have a vz sv6 with a raptor supercharger and manifold spacers, and was wanting to know if you guys make spacer washers out of your thermal composite materials? I can get the measurements for you, but what I am trying to achieve is to reduce conduction of heat to the charger bracket from the timing chain cover. All it is is a washer that is roughly 5-10mm thick, but will get exact measurements for you if you can do this.
Thanks, Richard
Hey Richard,
I can have a look at the drawing for you to quote the job, however it will be likely be more cost effect to just source nylon washer from your local bolt specialist and stack them up
If you have any other questions please don't hesitate to ask.
Cheers,
Steve
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
Ah ok, so short answer is that you don't make any form of washers from your thermal composite material?
Cheers Steve
MaceEngineering
