Howdy all i thought it would be a good idea to put up a thread for people that run mace products and to show what gains they have seen from them ill start
Car- Vn ecotec v6
Trans- Auto stage 2 shift kit
Diff- 3.7 open wheel
Suspension- king superlows all round
Exaughst- catback lukey
Mods- * mace 1.98 rockers
* mace 12mm plen spacer
* mace 24mm main spacer
* mace 82c thermostat
* mace 69mm tb
* vt injectors
* l67 cold air intake
I got 129.3kw in 2nd cause my auto wouldent stay in 3rd on a mainline dyno with 298xxx on the motor
* tune by the1
tuning done by THE1 A+++++ tuner
And powering it by MACE
Build it to handle the MANG
VY L67
- ‘MACE’ A2A Intercooler adapter plate
- ‘MACE’ piping
- ‘MACE’ Intercooler system fitment kit
- FMIC 600x300
- ‘MACE’ ported LIM
- ‘MACE’ ported adapter plate
- 'MACE' ported supercharger
- ‘MACE’ 1.9 ratio rockers
- ‘MACE’ Larger throttle body
- ‘MACE’ Pulley and hub
- ‘MACE’ CAI
- 'MACE' 6mm Insulator
Power 206rwkw @ 12 PSI before porting blower, insulator and rebuilding auto
Jim's one
513rwkw V6
Hopefully it will be making even more once the motor is finished, which we've had a lot more input into this time round![]()
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
Just had a though,
In regards to people posting up results it would be ideal if people could show before and after dyno results because comparing results from different dyno facilities can be somewhat miss-leading but please post away with a list of your mods and results achieved.
Steve![]()
MaceEngineering
CAR- ve SV6 3.6l Sidi
BOX-Manual
MACE
-manifold insulators
-OTR CAI
-Custom tune
OTHER
x force cat back
long extractors + 100cpsi cats
3.9 diff gears
Power 176RWKW before OTR, diff gears, extractors and cats
COMING
- CAMS!!!
- Ported intake
MaceEngineering
Cheers adz, I'm pretty happy with we're it's at but theres always room for development and improvement wich keepts it fun!
Gotta be happy with ur charged 6. Sounds like its a weapon. I might think of going forced in the near future!
car -
vz sv6
mods -
mace manifold spacers
raptor supercharger
catback exhaust twin 2 1/2
3.46 diff gears LSD
Power -
315RWHP (235RWKW), 872RWNm in 3rd gear
need extractors and high flow cats![]()
MaceEngineering
Yea, couldn't believe it made that figure, supposedly another 30-40rwhp when I do the rest of the exhaust so I'm told
vy calais l67
mace cai (modified to fit 4" intake)
mace 1.9:1 rockers
mace 10psi pulley kit
2.5" twin catback
ran a 15.1 on 6psi with above mods
and a 14.7 on 10psi with above mods
since then have added extractors, high flow cats, tune, 3.46 lsd.
am yet to retest due to the diff clunking i'm pointing my finger at the driveshafts/axles!
I have drive shafts for you bro
i got the calais to do the clunk on command yesterday, got the missus to drive full lock right while i jumped under the car and held on to the fuel tank and got dragged along (only going like .5kmh) you can see both axle binding up from insided the diff then letting go with a bang at the same time. lsd is fu%^ed i think! im gonna take it out and put the single pegger back in. and source a lsd rebulid kit.
and staying with topic i dont have apower figure yet to go with my 1/4 times but i estimate between 150-170rwkw maybe?
VY Acclaim
Mods:
Pacemaker extractors into stock cat then to a single 2.5" lukey system
25mm Manifold Spacer
made 111rwkw but i have since got the 82 degree thermostat and the cold air intake so i would say closer to 115-120rwkw now
It could be the fact that the LS has preload on the cones from factory, to prevent it slipping under power and lasting longer, under high load conditions.
As a consequence though it's probably acting like a locker and chattering at low speeds and loads (?)
That's a relatively healthy figure, considering the 25mm manifold insulator doesn't add too much to the peak power (if at all), as they really shine on the bottom to mid range. It's for this reason ecotecs drive noticeably better with them installed under real world conditions.
MaceEngineering
i should have also mentioned that it had around 350nm of torque at about 2300rpm
yer i thought it could be really bad chatter! but it gets a wickid BANG happening. i've got castrol 80/140 xa something something. it states it already has the additive for diff chatter but i think i might add another bottle.
I see. Can try some additional additive, before taking the diff out I guess
MaceEngineering
If it was diff chatter you would know because the inside wheel would be trying to skip (If the LSD was locking). from the factory the pre-load on the cones/backlash on the spider gears isn't ideal for performance conditions. This is the reason they single peg fairly easily when abused. When you get the LSD rebuilt make sure they fit a decent spring for the cones pre-load and set the spider gear back lash properly, the LSD will last a LOT longer this way.
Being a IRS model car, check the diff mounts as well as this can also cause issues with traction![]()
Body by Holden, Soul by Brock
the Legend will live forever
