Results 1 to 11 of 11
Thread: 25mm Manifold Insulators will it fit
    VX Equipe
    Dec 2011
    rockhampton
    Default 25mm Manifold Insulators will it fit
    Anyone with a VT/VX commodore that has had a 25mm Manifold Spacer does it fit perfect or will i have to drop down to a 12mm
    Thanks
    Andrew
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    I have a VS with a 25. It only just rubs the bonnet lining clips.
    Should be right mate.
    If your really concerned PM Steve (Mace) about it and he'll answer all your questions.
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VX Equipe
    Dec 2011
    rockhampton
    i think there is a big differnece in a vx then a vs ie. body size, weight ect so i going to need someone else that has a vt or vx about this and how much differnce u notice when u installed it
    VX Equipe
    Dec 2011
    rockhampton
    Ive asked MACE (Steve) already its an umm and a rrrr about it really which is why im looking for someone with same make as me because everyone knows trust customers more then the salesman in this case i trust both i just need someone who has brought these mods and fitted fine or needed to trim whatever or it was to big. And once i have them installed ill give a full proper review how to install, if u need any clearance and performance ect. in searching for post many people who have brought the manifold insulator and spacers have been vs's and no vt-vx's and if there was they didnt really tell much.
    Jezza's Avatar
    Jezza is offline Ecotec Just Kicked In!
    VYII Acclaim
    Apr 2009
    South Australia
    i have a vy and the 25mm manifold spacer fits fine otherwise my strut brace wouldnt fit
    Quote Originally Posted by SHEENY05 View Post
    I have always thought a quick six will turn more heads cause if you gear a V8 you sorta expect it to go hard
    VX Equipe
    Dec 2011
    rockhampton
    Jezza's Avatar
    VYII Acclaim
    Apr 2009
    South Australia
    i didn't bother putting the cover back on so i wouldn't know
    VX Equipe
    Dec 2011
    rockhampton
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    No, because the engine cover traps heats and you can clean your manifold/Plenum to make it look alright..
    I have 25MM in my VY also, I'm pretty sure the engine cover wont fit without mods. But i have both spacers.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    VX Equipe
    Dec 2011
    rockhampton
    Mar 2008
    As a general rule of thumb with the spacers
    In regards to the engine cover and these spacer your best bet would be to take a couple of measurements just to make sure as every car is different; fitment summary from experience for your car is as shown below.
    * Raising manifold by 12mm: Cover will go on like factory
    * Raising manifold by 25mm: Cover will need to be trimmed around the alternator or bonnet liner needs to be removed or trimmed. Otherwise cover will rub on bonnet liner
    * Raising manifold by 37mm: Cover will need to be trimmed around the alternator and other parts along with the bonnet liner needing to be removed. Otherwise cover will rub on bonnet liner/possibly not close depending engine mounts
    * Raising manifold by 50mm: No hope of keeping cover without some serious bonnet mods. Will still require bonnet mods without cover
    There have been some cases though where new aftermarket engine mounts have limited increasing manifold height by only 25mm, hence the reason why it's important to take measurements.
    Hope this helps
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  1. 25mm manifold and 12mm plenum spacer
    By DevilDRake in forum Mace Engineering
    Last Post: 25-05-2012, 10:56 AM
  2. manifold insulators
    By Chris1991 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-12-2011, 05:58 PM
  3. manifold insulators
    By brentbrah in forum V6 Development And Modification
    Last Post: 25-10-2011, 08:57 PM
  4. DIY Manifold Insulators?
    By sweefu in forum V6 Development And Modification
    Last Post: 27-02-2010, 02:13 PM
  5. manifold insulators
    By Archers in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-05-2009, 09:58 AM
