Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Thread: Manifold insulators problem/flaw?
    VZ SV6 155.1RWKW
    Jun 2010
    Default Manifold insulators problem/flaw?
    Hey everyone,
    At the moment my setup on my VZ SV6 is something like
    Pacemaker full length headers
    100 cell stainless cats (i think)
    2 1/4 inch catback
    Underdrive pulley
    Mace Insulators
    Growler Intake (previously mace)
    VCM tuned
    Pulling around 155.1rwkw...
    Now i've had the insulators in from the beginning of modding the car and can't remember whether it did it without them. The problem occurs in active select in 2nd gear.
    When changing from 1st to 2nd gear around 3000rpm the car during acceleration in 2nd will have a hiccup around 2300rpm. The revs go up, cut out then start back at around 2100rpm.
    Its more prominent at half throttle. I can also replicate the problem at most mid range revs if i take off in first 1/2 to 2/3 throttle and change at around 4000rpm into second, again it will accelerate for a while then cut out as if it was in a phantom gear (only dropping by about 200 revs) and continue to accelerate.
    It only happens in second gear.
    Can it be confirmed if the change in runner length after the insulators causes confusion in the computer hence causing uneven acceleration?
    Can anyone tell me if anyone else experiences this problem and is a common but accepted flaw in the vz alloytecs?
    And lastly while im here, is it possible to remove the plenum and inlet manifold at once to reach the head as i have a snapped plenum to head bolt that I need to remove.....
    ANY THOUGHTS WOULD BE APPRECIATED!
    Ps. The car has been tuned before the exhaust and after all mods and the problem was still there making me think it could be a factory flaw... But I will be taking the insulators off to see if it resolves the problem.
    VZ SV6 155.1RWKW
    Jun 2010
    1998 Mercedes Vito 113
    Oct 2009
    S.E VIC
    There's been no problem with mine, but mine is a VY not VZ.
    I was almost going to call bullshit on the figures, but then i realised you were talking about a VZ not a VY.
    Quote Originally Posted by perkoracin
    it like u pull at to a red light and they go o its that fag from just Commodores and it like u go tohe drags and ur car runs a like a 9 sec run as a eg and theres run a low 14 um i would Lol so hard like Epicly and then call them The Internet Mouthers and no go Lol thats a eg they might have Fast as rides 2 but may not sound as a Nice small block chevy with a Supercharger on it lol.
    Click here for my old VY Commodore!
    VZ SV6 155.1RWKW
    Jun 2010
    Haha, nah its a VZ...
    I had another mate with a vz ute that ive been in but didnt get a chance to drive it before he sold it, I think his might have had the same problem in active select but can't remember too well. It was stock.
    The only other thing is maybe if someone else with a VZ 5spd auto can see if happens in there car and post back...
    VE SV6 ute
    Apr 2009
    vic
    I'd blame the tune before I blamed the manifold insulators. There is no reason why increasing the runner length would do this unless the tune is out imo
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Quote Originally Posted by treyflip View Post
    I'd be blaming this Before anything else.
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Flat spots would be tune related or a vac leak from the broken bolts. No way that will be from the spacers
    Body by Holden, Soul by Brock
    the Legend will live forever
    VZ SV6 155.1RWKW
    Jun 2010
    everything is sealed and it has.nothing to do with the bolt. its been there eversince I've had the spacers. it was there.before the exhaust before and after two tunes... its not.a.vacuum leak. also its not as though it just hovers.on a certain rev like a flat spot its more like the car changes into another gear.. sorry i can't explain it any better. it does not happen in drive only active select
    EDIT: "its been there eversince I've had the spacers." meaning the flaw in acceleration not the snapped bolt. the bolt only happened a couple days ago. This problem has been since i can remember which was when i changed to the spacers.
    VY Spac l67
    Aug 2008
    the fact that it doesn't occur in drive tells me it probably not the spacers. If you are sure that it only happens in active select then my money would be on the auto or tune.
    VZ SV6 155.1RWKW
    Jun 2010
    as it seems like a phantom gear, could it be related to the gearbox or diff? i mean the car seems like it has 2 changes per gear in auto, i dont understand that? im beginning to think im going to have to accept that auto alloytecs are spastics of cars. unless someone else with a 2005 sv6 could test it out for me and see if it happens in theirs..
    vs v6 wagon
    Apr 2010
    So remove the spacers ASAP and see what happens.
    Does the VZ have a power button on the auto trans ?
    200rpm - 300rpm is the approx the diff between the economy mode and power mod.
    Is it caught between the 2 programs when trying 2 shift between gears?
    This is what my VS does when I manually play with the power button.
    Take it easy on me I am not a mechanic just thinking out loud on the internet.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by vsv6dude View Post
    ^^ this is the only way to truly rule out the spaces as an issue, or the issue.
    VE Omega
    Nov 2009
    Here
    I want to buy a set of these insulators. I need to contact Mace. They will work with the CPR6 I trust.
    Mar 2008
    Can take them off to see how it goes I guess. I'm guessing it's more to do with the calibration myself, or lack there of with the 5 speed autos sadly
    If the problem still occurs, you may want to consider physically bumping up the line pressure in the box to prevent it from slipping between gears.
    Or there maybe something mechanically wrong with the box, who knows. It's a case of process of elimination now, to resolve your issue.
    The problem you're experiencing is definitely not common, based on the shear number of insulators we've supplied over the years, so I would be most grateful to be kept in the loop as to what the outcome is
    Please keep us posted
    Cheers,
    Steve
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
  15. #15
    Mar 2008
    Quote Originally Posted by Z3RO View Post
    On VE's apparently they actually make the installation process of the CPR6 easier. The only catch is that the manifold can rub up against the plastic cowl of the firewall (apparently not an issue) and longer bolts are required (which we don't supply)
    If you have any other questions please don't hesitate to ask.
    Cheers,
    Steve
    MaceEngineering
  16. #16
    Apr 2006
    Auckland NZ
    If it's only doing it in active select and not when in normal Drive then it's a tuning issue otherwise it would also happen when it's in drive. I would suggest that the issue is most likely related to the torque management function (aka torque limiting) due to the fact that the 5speed auto's are a bit weak.
    Problem may not be as noticeable with the spacers removed because of the reduced torque
  17. #17
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Mine does this with the spacers in A/S mode aswell. Mine actually does it in 3rd, 4th and 5th and it is just the Torque converter locking up as it is suppose to. Though since i got the spacers it has started doing it in second gear where the Torque converter can not lockup so it has to be a different issue???
    I think immortality might be on to something there. Since the spacers add torque down low the computer may be getting confused. Ive had most of the torque management taken out with a VCM tune though i know Dale could not get rid of all of it.
    2.5" Single catback, LSD with 3.46 diff gears, Mace Manifold spacer, K&N panel filter ,VCM Dyno tune, RDA slotted and dimpled rotors.
    More mods to come
  18. #18
    Phantom vz sv6
    Sep 2011
    I have a similar thing in my sv6 in drive which feels like a small flat spot on the rev range somewhere in the high 2000's, haven't tried it in a/s but I will and report back if anything weird happens. Feels like the revs hover for a sec then continue upward without dropping.
    Question for Steve: were the vz insulators made for keeping intake temps down primarily? And was the thickness of the insulator 12mm for heat reasons or was that a calculated thickness which aided the runner length for smoother airflow and better torque, I've always wondered if perhaps the flat spot it turbulence in the plenum/ runners?
    Cheers!
  19. #19
    Mar 2008
    Quote Originally Posted by Stewlz View Post
    Cheers!
    "were the vz insulators made for keeping intake temps down primarily?"
    Runner length
    "And was the thickness of the insulator 12mm for heat reasons or was that a calculated thickness which aided the runner length for smoother airflow and better torque"
    The thickest spacer we could go
    "I've always wondered if perhaps the flat spot it turbulence in the plenum/ runners?"
    It appears most likely calibration related, in particular the 5 speed auto component.
    Does this happen to anyone else in their alloytec, especially in drive?
    MaceEngineering
  20. #20
    VZ SV6 155.1RWKW
    Jun 2010
    Ok so right now im waiting for the car too cool down completely as i already have 1 snapped plenum bolt , but when its ready im pulling the plenum and inlet manifold to get the bolt out, replacing the inlet gasket and removing the spacers and putting a normal gasket, and changing my 5 old remaining coil packs.
    After this, hoping all goes well, i'll have brand new coilpacks and spark plugs, no spacers, car will be sealed nicely and i will reset the computer and see how it runs. If it still does it then it is completely auto related. The tuner did a great job on the tune (twice) and i dont think this problem can be addressed via tune.
    MACE, could you elaborate on the line pressures? how can it be done and will this give firmer shifts? im very interested!
    In the mean time heres a direct like to a video of it happening around 3500rpm.
    http://img7.imageshack.us/img7/121/qjr.mp4
  21. #21
    Phantom vz sv6
    Sep 2011
    Yeh that's real weird mines nothing like that, just a hiccup. Cheers for the reply mace.
  22. #22
    Mar 2009
    Yep that's exactly what happens with mine with the spacers.
    More mods to come
  23. #23
    Mar 2008
    If it's torque management related (which I think it is), then it's likely that nothing else can be done with the calibration. I'm not confident that firming up the line pressures in the box will help either as the computer may spoil the party by backing off the throttle
    Does it still have the factory tune?
    Quote Originally Posted by torana355 View Post
    Does it happen anywhere else, besides under high load?
    MaceEngineering
  24. #24
    Mar 2009
    Quote Originally Posted by MACE View Post
    Yeah it happens in all gears except 1st, so the engine needs to be under load. I can understand why it does it in 3rd though to 5th due to the torque converter lockup but it should not do it in second gear.
    More mods to come
  25. #25
    Mar 2008
    Probably the fact that there is now more being produced by the insulators, hence the problem occurring. If Dale couldn't sort it then it would be very likely a limitation of the tuning software. I could be wrong though, therefor an open to other possibilities
    MaceEngineering
  1. manifold insulators
    By Chris1991 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 13-12-2011, 05:58 PM
  2. manifold insulators
    By brentbrah in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-10-2011, 10:31 PM
  3. manifold insulators
    By brentbrah in forum V6 Development And Modification
    Last Post: 25-10-2011, 08:57 PM
  4. Manifold Insulators - What are they?
    By Maccas90 in forum Mace Engineering
    Last Post: 19-07-2010, 09:34 AM
  5. DIY Manifold Insulators?
    By sweefu in forum V6 Development And Modification
    Last Post: 27-02-2010, 02:13 PM
