Hi all
Just recently had my 2003 acclaim tuned by Mace Engineering
Mods done
Mace bored out 69mm throttle body
Mace cold air intake
Geni extractors
2 and half inch catback manta system with rear only straight through muffler
Noticable improvement in the low down torque range say from 2000 to 4000rpm and the auto shift points
quicker and firmer.
Engine thermo fan comes on earlier as well I noticed
Basically the fuel and ignition maps are recalibrated but keep in mind that you must run 98 octane fuel due
to being tuned for it.
Good thing is that the new PCM is a outright purchase so you don't need to send in the stock one to get
reprogrammed. You just need your VIN number and modifcations details to suit the tune a new PCM gets
posted out via express post.
Kudos to Steve and the team at mace engineering for the professional customer service
Any questions people and I'll answer them
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
Just wouldering what else was changed in the tune apart from the fuel,ignition, thermo fans, and auto shift
points
MaceEngineering
What about fuel use ? Improved or use more fuel ?
I thought with the MACE chips you can still run 91 unleaded, as some of the factory tuning was retained ?
Improved fuel economy as now my average is 8.2lt/100km give or take on highway driving...around town it didn't use that much more.
Mace memcal chips can still run on 91 or 98 octane
For some reason when I got new the PCM it clearly stated in the custom tune form it said "please note you must use 98 octane fuel.
if it tells u to use 98 and u use 91 what happens tho i use 98 all the time because at the end of the day its only a couple bucks more but just wondering what would happen if u used 91 instead of 98??
will retard, possible pinging/knock if it's really bad fuel and loose power.
As above ^^^
MaceEngineering
So with MACE memcals use must 98 ron then.
I am assuming the PCM stated in this thread is supplied by MACE.
The advertising for the memcals states power increase is available from even using 91 Ron , see below
"Each MEMCAL is recalibrated to suit your specific engine and gearbox type, as well as the model of Commodore you own.
Horsepower gains vary beteen different models and the condition of your particular engine. Our estimate is
a gain of about 8 to 12kW using standard 91-RON fuel, with an extra 2% using premium fuel."
There is no room for compensation for lower quality fuels ?
I infer from the comments in RED its a multi use memcal for all fuel types.
MACE you need to make the website clearer.
Do you mean you when state "recalibrated to suit your specific engine...." each memcal can be customised to your selected preference for fuel.
And once programmed to your fuel preference you must use that fuel whilst the reprogrammed memcal is in the computer.
No, that's not what was said.
The PCM will retard the timing if it detects knock/ping, which can happen on a tune that has the timing advanced for 98. The result of retarding the timing is a loss of some acceleration (power).
How much did the PCM tune set ya back? Did MACE do it for ya in melbourne? Keen for my VY.![]()
nathans VY Calais - 'Calais 2.0' | VT Equipe | VS Calais **SOLD!**
Cost me $302.00 and the new PCM was sent by express post to me as the tuning is done on their end.
From 2000-4000rpm range is quite noticeable and the auto shift points are firmer and quicker.
Tune wont give you a whole lot more kw's Al. Maybe 5 to 10kw. It will bring better fuel economy and make the gearshifts more sporty like. It's more about drivability rather than gaining lots more power![]()
As above ^^^
MaceEngineering
A tuned PCM arrived this week from MACE for my VY, car now drives how it should have out of the factory, it is much more a pleasure to drive now, gear shifts now have no delay and from about 2000-5/6000rpm the power output is much more noticeable, normally with say quarter throttle 0-60kph would take a few seconds, now it is already there and I am having to brake as it has been catching me out, power delivery is smooth at light throttle, the car now gets a squat going on once it hits 3000rpm at WOT, I have imported the bin file off my old standard VY and matched it to this one to my laptop and after having a quick 15 minute read of the bin file it looks as though the timing has been advance 5 Degrees across the board as well as a few other tweaks for the transmission shifts, everything else has stayed the same but I am yet to look closer into this so I know what to change on my original for my Supercharged tune when needed, although one thing is I did have extreme popping at 5000+ rpm at first, I am running 98 octane plus +10 octane booster, after I changed the plugs to some new platinum's it was mint so make sure your electrical and spark is optimal
Thanks Steve much appreciated
Simon
MaceEngineering
hey steve
Got my tune today very happy car goes great and the shift on the auto is so much better no more lag. Just one question now that it is tuned for my larger throttle body do i need to remove the restrictor in the tube or leave it in.
You can remove it if you wish
MaceEngineering
Is there any difference with it in or out
