Results 1 to 14 of 14
Thread: MACE Support for Supercharger?
    Jarp's Avatar
    Jarp is offline Surely You Jest
    SV6 MY10
    Dec 2009
    Default MACE Support for Supercharger?
    Steve just wondering what you thought about the use of a kit like this one Sidi v6 supercharged? for our Commo LLT
    ie 1. What do you think the chance would be that it could be adapted to fit the Commo?
    2. Would MACE be able to support a tune for it or would it be necessary to purchase the tune from IPF Supercharger - Camaro V6 *DEPOSIT*
    Just thought I'd run it by you
    Mar 2008
    "Steve just wondering what you thought about the use of a kit like this one Sidi v6 supercharged? for our Commo LLT"
    I've seen it before and it does look good
    "1. What do you think the chance would be that it could be adapted to fit the Commo?"
    The bracket and blower would be fine, however I'm not sure about the front mount and piping. The piping would likely require to be reworked
    "2. Would MACE be able to support a tune for it or would it be necessary to purchase the tune from IPF Supercharger - Camaro V6 *DEPOSIT*"
    The tune 100% won't be a problem
    "Just thought I'd run it by you "
    No probs
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    2010 VE SV6 Ute and 2010 VE SSV Sedan
    Nov 2009
    And Jarp is getting excited about a possible birthday and/or Christmas present for himself next year :P
    Would be sweet if you can make it work haha
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Quote Originally Posted by bigjim92 View Post
    Ya not wrong...warranty up next year and I'm my head off. If 300+RWKW possible for 5-6k then I'd be keen as although would also have to do brakes. Just emailed CAPA to see where they are at as they told me 6 months ago that it was in the pipeline. Have also wondered if one of these http://www.capa.com.au/kits_holden_ve_v6.htm could be easily adapted and then MACE tuned?
    Mar 2008
    I looked at the IRP kit again, I don't think that it will fit without modding the bracket or body work. The CAPA one would likely be the way to go. I think that the alloytec bracket may be suitable with the SIDI unit. Tuning no probs
    MaceEngineering
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Would need to have MAF adapter I assume? Any ideas about ADR approval for rego I'm also assuming this would come down to individual State/Territory legislation but might be a stumbling block.
    Mar 2008
    "Would need to have MAF adapter I assume?"
    Easy
    "Any ideas about ADR approval for rego I'm also assuming this would come down to individual State/Territory legislation but might be a stumbling block"
    Unless you have very very deep pockets, I think you'll find that these supercharger kits are for "OFF ROAD USE ONLY"
    MaceEngineering
    VE SV6 ute
    Apr 2009
    vic
    If I somehow get the funds together before the end of jan steve/jarp you're welcome to have a look at the bracket and see if it will fit the SIDI's. Might be a simple mod job!
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Is the S/C road the one you are taking Kuzman? I think it is the way to go from a bang for buck perspective, particularly as there is now no requirement to piggy back an ECU. I'd be keen to know if the VE Capa kits would bolt up to the SIDI so thanks for the bracket offer if you get to that point.
    VE SV6 ute
    Apr 2009
    vic
    It's the CAPA 10psi intercooled kit. Only thing is you'd need bigger injectors and I'm not sure who sells them here?
    Jarp's Avatar
    SV6 MY10
    Dec 2009
    Mmmmm I didn't see any mention of bigger injectors for the Camaro kit...will check that out.
    Mar 2008
    If fueling problems do arise with the SIDI's then a the cam lobe that activates the high pressure pump will need modded along with the pump etc.
    I don't think it will be a problem though, depending on how far you want to go I guess.
    The easiest way out though would be to run a microfueller with additional injectors in the top of the manifold.
    MaceEngineering
    VE SV6 ute
    Apr 2009
    vic
    Would you recommend this for the alloytec too? I was going to get 440c injectors, are these big enough? or should I go 450c?
    Mar 2008
    Quote Originally Posted by kuzman89 View Post
    440's will be fine for the job
    MaceEngineering
  1. Vk apron and rad support. Where to buy?
    By seq4x4 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-03-2011, 05:22 PM
  2. pulling out rad support?
    By Keesh in forum Spray Painting and Panel Beating
    Last Post: 22-08-2010, 10:00 PM
  3. VR VS radior support
    By b.e.a.s.t. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2009, 11:12 AM
  4. tech support
    By Fr3ak+-- in forum The LAN Lounge
    Last Post: 30-09-2008, 01:41 PM
  5. moral support
    By vn_lexcen_s2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-02-2006, 01:09 PM
