Page 1 of 3 123 LastLast
Results 1 to 25 of 60
Like Tree1Likes
Thread: What does everyone think about these
    VX Equipe
    Dec 2011
    rockhampton
    Default What does everyone think about these
    4L60e Single Stage Shift Kit - $70.00 : Shiftkits Australia, Performance Shift Kits and Vehicle Electronics
    Has anyone got any criticism comments or advise on this shift kit all advise welcomed
    Andrew
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Looks to me like something similar to the old power chip that was just a resistor.
    The only way to fit a shift kit is to actually fit a shift kit, not a switch.
    Visit my Facebook page
    01 VX Executive Series ll
    Sep 2011
    Bathurst
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Isn't that the one that changes line pressure to give the feeling of faster shifts?.
    Best bet if going cheap as possible go the servo kit.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VX Equipe
    Dec 2011
    rockhampton
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Quote Originally Posted by vxcp View Post
    ok ill stick with a stall converter then
    Err what you on about?
    308 vc
    Dec 2010
    North east Adelaide
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Na there not that dodge, there just basically a "hard wired alteration" to the tune that tells the ecu to bump up the gear box line pressure. Just same as the ls1 boys boys do via vcm, kalmaker etc etc. I had this done in my tune (not this item but same software changes) it does help but I still ended up going billet servos and shift kit.
    Wanted to buy VC sunroof
    Pm me
    Mar 2008
    I'll go against the grain here and say that I'm a fan of these
    The main reason is that you can easily shift between trans shift settings (shift firmness) at the flick of a switch. This comes in handy say if you're driving the car in the wet and you don't want it to kick out etc.
    If you're planning on getting a custom tune then it's not all that relevant as this can be controlled via the power button
    MACE Engineering Group
    www.maceengineering.com.au
    Powering Australia's best Commodores
    Find us on Facebook:
    MaceEngineering
    VX Equipe
    Dec 2011
    rockhampton
    ahhh ok thanks guys well ill be getting a tune from MACE either them or maybe get it tuned wen im doing the dynos and wraith this Holden Commodore VN/VX Hi Stall Torque Converter | eBay
    Also another question Steve is it wasting my money if i buy ur chip but then have it tuned by a dyno shop in rocky or would both be better thanks.
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    You don't need that converter on a stock motor. Get the box properly shift kitted first.
    VX Equipe
    Dec 2011
    rockhampton
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    I got quoted about $500. Ring up your local transmission place and ask.
    VX Equipe
    Dec 2011
    rockhampton
    wow that is like 50 dollars dearer then the high stall torque converter well ill go that i wanna get a cam first
  15. #15
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Pretty pointless going a stall if your still using the standard auto.
  16. #16
    aaronsteven's Avatar
    aaronsteven is offline aaron steven
    VX Executive S2
    Jan 2012
    Rego Park, NY
    VX Equipe
    Dec 2011
    rockhampton
  18. #18
    VT S2 - SS intirior - Ls1 Project!
    May 2011
    Sunny coast
    I have a box setup atm.. its a 4L60E Rebult stronger, 3000 stall, full manual, corvet servo's etc.. bam there goes 4g done buy a profesinal.. dont bother with a factory 4L60E its gong to blow if you dont give it a hand....
    But your going to wack a cam in and leave rest of the motor standard?.. hmm seems errr stupid to me?
  19. #19
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    Quote Originally Posted by MACE View Post
    Hate to disagree with you Steve but regardless of how hard your transmission changes gears its still all up to the driver and his right foot....
    it can also have issues with the torque reduction programmed into the ECU which means the higher you rev the less hard it will change
  20. #20
    Mar 2008
    Quote Originally Posted by Munz View Post
    I'm all for healthy disagreements Monotonous arguments with the misses on the other hand is a big NO LOL
    I know it's a dirty way of controlling the force motor in the trans, but it does work with no torque reductions, only firmer shifts (VY V6's and earlier)
    Bare in mind I'm not taking about more sophisticated OBDII computers as found in LS1's and Alloytecs. I'm sure the computer would be more inclined to throw an error code or pick up the increase in instantaneous torque from auto and make changes accordingly bringing it back to factory spec. I can't definitively say this is the case though.
    MaceEngineering
  21. #21
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by scott-95 View Post
    $4000 on modding an auto gearbox, when you don't even know if your putting a modified V6 or an LS1 into it, is a bit of a errr stupid move in my opinion!
    How much power are you expecting to get from your possibly modified V6 or LS1?
    P.s. A V6 Ecotec with every possible mod done will #### up a LS1 crate motor easily, depending on how far you go with it!!
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
  22. #22
    May 2011
    Sunny coast
    Quote Originally Posted by TI3VOM View Post
    Totaly diffrent car bud
    and i didnt pay for the box, just have receets from prevous owner
  23. #23
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I had one of those electronic *ahem* shift kits, and let me say, it was crap. Car slammed into gear when moving around the driveway, and did sweet-fa when at high revs, completely the opposite of what you want.
    Seriously when changing from reverse to drive,out of my driveway, the whole car would jerk forward, the shift was that hard.
    I understand that you would really only use it when your going to have some fun, but like I said at higher revs the auto shifts almost the same as before. But I think this is due to the ECU scaling back.
    Ronald Reagan (1986)
  24. #24
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    The reason it feels no different at high rpm and slams into gear is because all that thing does is trick the ecu to shift at max pressure. At high rpm it shifts at max pressure anyway.
  25. #25
    VX Equipe
    Dec 2011
    rockhampton
    thanks acarmody wont be getting it lol next mods to come are tune, rockers or cam (being a p plate dont think u can drive it with a lumpy cam cause it an engine mod correct???) and throttle body.
    So far ive got Pacemakers, twin Xforce 2.5 inch exhaust, 2 twin aftermarket high flow cats, 25mm manifold insulator, 12 mm spacer and CAI. Haven't put the last 3 items on yet as i wanna get a dyno b4 and after for MACE and for all use, so you have a fair indication of how much your getting out of it.
    By the way my birthday today and im still drunk haha
