Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By MACE
Thread: Smallest Supercharger Pulley Without Intercooling?
    scvs6's Avatar
    scvs6 is offline BLOWN VS BERLINA
    '95 VS Berlina L67, '11 Colorado, '01 TJ Magna 3.5
    May 2011
    Ballarat, VIC
    Default Smallest Supercharger Pulley Without Intercooling?
    Hey,
    I tried doing a search but it doesn't seem to be working at the moment.
    With my VS L67, what is the smallest supercharger pulley (PSI) that I can install and run safely without an intercooler?
    I would like to get an intercooler, but unfortunately I don't have the time or money to fit one at the moment.
    Cheers,
    Ben.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW 540i
    Jul 2004
    S/E Subs, Melb
    10psi, It's advised to run a cooler with 10psi, But a nice tune will see you sitting fine with that without a cooler.
    Mat
    In my world I'm the one an only king, if your searching for the truth then you've got to look within.
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by HoZy View Post
    Mat
    Ok no worries, thanks mate. Yeah i'll get it tuned, and I still might get an intercooler one day, but I can't at this stage.
    VS Stato l67
    Mar 2009
    Mornington, Melb
    You dont even need a tune with a 10psi, just to run 98 octane. Ive done 80,000ks with my 10psi pulley, 250k on the engine and still going good
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by monkeys437 View Post
    Oh ok, I have been filling up with BP Ultimate ever since I fitted the engine. It was recommended by the people that reconditioned the engine.
    Huntington is offline Donating Member
    VX SS
    Jun 2010
    Ballarat
    You will be fine without a tune at 10psi. I was running one for ages before the cooler.
    VS Stato l67
    Mar 2009
    Mornington, Melb
    Quote Originally Posted by scvs6 View Post
    I use Mobil 98 or BP Ulitmate. I've heard they are the best stuff and have the most stable octane ratings or something.
    Mar 2008
    10psi pulley on a good working order L67 and quality 98 octane fuel will run all day everyday without any probs
    MACE Engineering Group
    www.maceengineering.com.au
    ***Product Knowledgebase***
    Find us on Facebook:
    MaceEngineering
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Mar 2008
    Fully reconditioned L67, 98 Octane BP Ultimate, can't get much better then that. Thanks for the help guys
    As long as the comp is around standard then you'll be right
    MaceEngineering
    scvs6's Avatar
    May 2011
    Ballarat, VIC
    Quote Originally Posted by MACE View Post
    Yeah it was fully reconditioned to factory specs
    Ill buy the pulley off you once I get my Statesman back from the panel shop, just because i'm not sure how much they are going to charge for the repairs haha.
    Mar 2008
    '12 Px ranger 4x4
    Moto X Champion!
    Mar 2009
    Townsville, QLD
    from the data logging i've done on the calais (10psi) i've noticed that the stock memcal can deal with the extra boost, however in warmer climates ie. townsville the stock memcal gets some wicked knock retard bringing timing down a fair bit! roughly the stock tune will be around 13 however with upto 10degrees k/r i was seeing only 3degrees advance in some runs.
    atm im running upto 13degrees advance with no k/r due to the fact i've bumped the fuel up a fair bit! stock memcal afr under WOT were around the 13 mark. now mine sits at 11.6-8.
    steve what would be the highest psi a non cooled car could run with a tune? i was thinking maybe 12-13? that will see between 8-10psi for low to mid rpm working its way up to the 12-13 in the higher revs? however you'd only be able to run stuff all advance to cope with the extra boost up top.
    Mar 2008
    Quote Originally Posted by drift-it View Post
    With a tune, standard cam with 1.98:1 rockers, 14psi in Adelaide. FNQ, with the factory air temp gauge (not in the LIM) I would keep it to around 12-13
    Cheers,
    Steve
    MaceEngineering
  15. #15
    vr calais&vl exec
    Oct 2004
    I run a 12psi pulley uncooled no probs, i have an xu6, always on vpower, 1.9 rockers, mace cai, stock hsv extractors & exhaust.
  16. #16
    VY Spac l67
    Aug 2008
    Ever thought of getting a memcal from mace for the 12 psi as your ecu may retard timing to reduce knock hence robbing you of power
  17. #17
    Mar 2008
    Quote Originally Posted by mjd1810 View Post
    mjd1810,
    Even though it's not pinging, the knock sensors could be pulling out timing hurting power. In saying this though we should be able to work something out
    Cheers,
    Steve
    MaceEngineering
  18. #18
    VS Stato l67
    Mar 2009
    Mornington, Melb
    It's not such an issue for us in Melb, but we still get some mad hot days in summer so I drive with a pretty light foot if the temp is in the high 30's or above just in case
  19. #19
    vr calais&vl exec
    Oct 2004
    mjd1810,
    Cheers,
    Steve
    very interested Steve, please tell me more.
  20. #20
    Mar 2008
    mjd1810,
    We basically run a richer mixture to keep the air cooler along with a few other things
    Cheers,
    Steve
    MaceEngineering
  1. Supercharger and boost levels /intercooling
    By SOUNDS LIKE SIDEWAYS!! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 08:47 AM
  2. Smallest pulley for raptor?
    By one_and_only2004 in forum Raptor Superchargers
    Last Post: 22-04-2010, 08:48 PM
  3. supercharger pulley
    By dannyn12 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-08-2009, 07:37 PM
  4. Cheapest, Smallest Supercharger for 5.0L
    By Vee-ard in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2009, 02:12 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
