Hey Guys,
I just bought a MACE throttle body of a guy in here and i have a feeling its for a VZ.
Is the VY a completely different Throttle Body?
Cheers![]()
vy is ecotec vz is alloytec i would guess they will be different.
Have a look at the instructions to confirm if you have the right throttle body.
http://www.maceengineering.com.au/We...STALLATION.pdf
Cheers,
Steve.
MACE Engineering Group
***Product Knowledgebase***
Find us on Facebook:
MaceEngineering
Hey Steve,
Do you make a throttle body for my ute?
Dean
MaceEngineering
Wouldn't VZ alloytec be Drive By Wire (DBW)
lol, i take it it didn't work out?
MaceEngineering
Steve, i bought a 2nd hand 69mm TB off a bloke (sorry, moneys tight atm) and not 100% sure if he sent the small restrictor you're meant to place in the rubber elbow when installing. Havent had a good look at the part yet to see if its there since its late, but if i dont have it will i need to source one? Stupid question i know, but im unsure of its role in the TB.
Tristo
MaceEngineering
Hi Mace
I have done the same and got a 70mm throttle body for my VR off Trademe over here in NZ. The only problem is that it now idles at about 2k rpm and does not change gear like it should(it's an auto). Took it down to Pit Stop and they said the Trottle position sensor was bung? Any help would be great.
I have put the old t/b back in but the problem is still there.
I have had to pull the bits and pieces off the standard t/b to put on the 70mm one.
HELP!!!
The new t/b had a piece of foam jammed in the inlet side if the idle air path as well(have since removed)
Hi Mace
"I have done the same and got a 70mm throttle body for my VR off Trademe over here in NZ. The only problem is that it now idles at about 2k rpm and does not change gear like it should(it's an auto). Took it down to Pit Stop and they said the Trottle position sensor was bung? Any help would be great."
Aussuming that the TPS is fine (which it may not be) then there is a good possibility that the sleeve on the end of the TB shaft is missing. Please refer to the fitting instructions below
BORED OUT AND POLISHED THROTTLE BODY VN-VT - Mace Engineering Group
"I have put the old t/b back in but the problem is still there.
HELP!!!"
As above
"The new t/b had a piece of foam jammed in the inlet side if the idle air path as well(have since removed)"
I have no idea how that would have got there as we don't normally use foam for packing though in this case we may have (?)
Please keep us posted
Kindest Regards,
Steve
MaceEngineering
Cheers for all that Steve
The problem is still there (I made sure that the sleeve is still there) Must be the TPS then as it now idles at about 3000rpm.
Could it be that the butterfly inside the body is abit to large and is causing the tps not to close properley?
Remember that this tb was not "brand new". Was got from some bloke off trademe not one of your auctions. He did say that he got it from you guys tho.
I Used To Have a Open Mind But My Brains Kept Falling Out
Originally Posted by drewVHSS
If you wish to buy that, i have some sweat from the ball sack of an elderly yak, if you rub it on the rocker covers of your engine, it'll unleash 1-2 killerwasps of powah!.
"The problem is still there (I made sure that the sleeve is still there) Must be the TPS then as it now idles at about 3000rpm."
Could be
"Could it be that the butterfly inside the body is abit to large and is causing the tps not to close properley?"
The butterfly could be sticky, however that is only common with the thicker plane bearing shafts.
"Remember that this tb was not "brand new". Was got from some bloke off trademe not one of your auctions. He did say that he got it from you guys tho."
Without seeing it I couldn't tell you
We tried but no like![]()
MaceEngineering
My VS Acclaim - http://forums.justcommodores.com.au/...series-ii.html - Few bolt-ons with Lowered Suspension and Slotted Rotors
MaceEngineering
Alright sweet I'll get back to you on that inbox
No probs![]()
MaceEngineering
