Body by Holden, Soul by Brock
the Legend will live forever
Will do
In regards to the MAF haven't looked at it up close so I can't say. As for the throttle body the factory casting is too thin to justify any machining. And even if it could, the manifold has the same throat diameter as the throttle body, so this would require porting to see any gains![]()
hey mace!! Just wandering, any idea if the mace spacer for the ve alloytec and the CPR6 are compatible? Was told I wouldnt be able to close the bonnet.
Good excuse for a bonnet scoop xD lol
hey mace,
with your 1.9:1 rockers do you supply pushrods??? or will stock rods be fine?
how much are the twin throttle manifolds for the buick v6?
Curious on the cam prices you have. What type of power output etc. Price and fitting also please.
Originally Posted by Yoda
They should be compatible, in a that they will bolt up, however in regards to clearance I couldn't tell you.
With our 1.9:1 rockers pushrods are optional and are only required if you're installing them on a VY V6
We don't make them any more
Cam prices for new billet grinds start from $525. In regards to power outputs it depends on your requirements. Installation is normally around the 1000 mark.
I'm kind of funny. I like to be able to drive around normal cruise everyday thing. But when i want to go overtake or off the mark up to 100 i want a good throw back in the seat feeling. Maybe some 1/4 runs here and there also. But not killing all low down take off power in the process.
I have read some guys with cams who hate driving them around normal, They say they are like pigs. That is something i would love to avoid, But still get as much as i can out of it. I had the idea of roller rockers for some cheap get up and go, And i also like your insulation products, Been looking at them on ebay.
bring back the buick manifoldhell, id even settle for a high flow single t/b manifold :P . we need more in the way of buick parts!
HI Steve,
Just wondering (i think i noticed correctly) why the heat insulators between the plennum and manifold are made from bakelite and not a thermal resistive plastic? Or would it get too hot for the plastic? Bakelite just seems too old school ;o).
We'll I would probably suggest our higher ratio rockers as bang for buck they can't be beatNo only this but they are the best option available if you still want to maintain factory driveability. And the good thing is that we know offer a cam to suit these higher ratio rockers so if you wanted even more power later on down the track you can, whilst still keeping your higher rockers
The problem with the twins is that they were expensive to make, and that people weren't willing to pay what we though was a fair price to justify continuing to make themIn saying this though we may have something in the pipe line
The material in which they are made out of is a thermal composite material, which is highly resistant to temps given it's material properties.
The term composite going the description of wiki is
"Composite materials (or composites for short) are engineered materials made from two or more constituent materials with significantly different physical or chemical properties which remain separate and distinct on a macroscopic level within the finished structure."
We've gone a composite as it gives us excellent material properties given our requirements instead of over a straight plastic![]()
hey mace
what the price for twin throttle mainfold on buick?? as u cant make them anymore ?? will be interesting to know for everyone?? they look so good.
cheers
hey mace,
with your 1.9:1 rockers, are they worth getting with N/A or are they only suited to forced induction?
I should have come to you guys last year. I had a bit of money away just sitting around. I was going to buy some YT RR. Spoke to the guy and all i think he went away for Xmas. I couldn't get in contact with him after that. So there it sat little by little i removed it and ended up going away to Phillip island with friends and blew the lot.
Yes i like the idea of RR and Cam later. I have always had a figure in mind of about 200kw. Would i be able to reach this easy enough - even without exhaust and exstracters ?.
If were to be making them again we would probably be looking at around the $1500, including twin 70mm throttle bodies
The 1.9:1 and 1.98:1 rockers work like a champ on N/A cars![]()
That figure is doable, however you will need extractors and exhaust if you want that figure. Bang for buck though you can beat a set of rockers
You're correct in saying this however things like the rockers work surprisingly well on even a dead standard car. Another bang for buck mod would be a cat back exhaust system![]()
With your plennum insulators, you have quoted 10% increase in power for the 12mm one and 13% for the 25mm one. 25mm is 2 times (approx) thicker than the 12mm one but with only 3% increase in power (over a broader range). I don't know much about runner lenghts but would i be right in thinking that 25mm is about the optimal thickness for optimal power gains and any longer power figures would start to go backwards? Just thinking about some cars with Tunnel rams.
Forsure i will be adding them at some stage, Only i don't want to go exhaust and all first, Much rather try it from inside out.
I have always had the figure in my head 200. If i go RR and Cam i will go headers and system. Is there anything else the engine might need to strengthen it up at all ?, Or will it be fine with cam and RR running.
Thanks again for your time.
depending on the zize of the cam you go, youll need a higher stally to bring ur car up into its powerband so it isnt a pig off the line.
then things like leads, CAI, and a decent service, and youll have urself a decent amount of poke for a v6.
next step is diff gears, they wont change your power output, but will increase your accelleration with the loss of a bit of top end. (but when does a v6 have this anyway).
They use a material for the Spacers which is a thermal Composite.
Plastics - at least the common ones, Have operating temperatures that are too low for Engine bay use. Reinforced plastics (FRP's etc) are much more expensive, and still may have heat aging problems.
this gear is ideal for the purpose, and has been used as carb spacers since adam modded his daddies T bucket back when it have 200 ox power.
It's immune to most solvents, has enormous mechanical strength, and its continuous operating temperature is 130 degrees, with peak (short term) temp ability at 155 deg celsius. It can be well finished with standard machining tools and is readily available. It's also incredibley useful as a thermal and electrical insulator.
Teflon and specialist plastics all have down sides, be it cost, mechanical ability or machinability. Carbon based composites conduct too much heat. Trust the stuff - it ticks all the boxes.
Can you tell I worked in plastics and Insulating materials ?
Thanks Tsunamix, thats the answer i was looking for.
Sounds very good.
I like the hydratrac 3.46 should have got it when it was $400next step is diff gears, they wont change your power output, but will increase your accelleration with the loss of a bit of top end. (but when does a v6 have this anyway ).. That is true, It's all about 0-120 with a V6 the rest isn't as exciting
. But that is most of the days driving 0-120.
Looking forward to receiving another set of 1.98:1 rockers next week for a customer!
Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's and Alloytec's
