Page 1 of 28 1234511 ... LastLast
Results 1 to 25 of 693
Like Tree3Likes
Thread: V6 Peformance Parts
    Mar 2008
    Default V6 Peformance Parts
    HIGH RATIO ROLLER ROCKERS
    High ratio (1.9:1) & ultra high ratio (1.98:1) roller rockers (stock ratio is 1.65:1) to suit EcoTec V6’s in both naturally aspirated and supercharged form (L36 and L67 engines). A very cost effective way to bump up the performance of your late model Commodore, by increasing valve lift thereby allowing your engine to breathe much more efficiently.
    COLD AIR INTAKE MANIFOLD INSULATORS
    Manifold insulators are a thermal insulating spacer that mounts between your upper and lower intake manifold. Made from a heat blocking composite, our manifold insulators will increase power from your engine by keeping the intake cooler, and increase low end torque by increasing runner length. Available in both 12mm & 25mm thicknesses for the ecotec & 12mm for the alloytec. Increases low end power by at least 10%!
    CNC PRECISION PORTED THROTTLE BODY
    CNC precision ported throttle body is enlarged to a final diameter of 70mm for VN-VR V6 & to a final diameter of 69mm for VS-VY, increasing maximum airflow by over 30%. Backed up by testing, gains of around 10 HP at the rear wheels are to be had if used in conjunction with extractors/exhaust and cold air intake. A greater power gain can be achieved if more mods have been undertaken such as a larger cam, supercharger etc…
    MASS AIRFLOW METERS
    Installing a large MAF is a very cost effective way to bump up the performance of your late model commodore by significantly increasing air flow through the intake. Available in both 74mm and 85mm.
    PERFORMANCE PLENUM SPACER
    A Plenum spacer is a special spacer that sits between your plenum cover and intake manifold. It's main purpose is to improve air distribution between cylinders by slowing down the air speed inside the plenum chamber. As a result there is less of a pressure drop inside the plenum chamber between cylinders, and less air momentum, resulting in better air distribution and power. Available in both 12mm & 25mm thickness.
    COLD AIR INTAKE ENCLOSURES
    New generation cold air intake/boxes to suit Commodores VB-VZ and Statesmans from VN-VZ, which are a direct bolt on drop-in replacement for your existing air box assembly. The kits include an all new air box, airflow meter safe pod filter, along with mounting hardware required for complete installation.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Hi steve, do you have anything for the buick V6 engines?
    Body by Holden, Soul by Brock
    the Legend will live forever
    Col74 is offline Col74
    VS Calais S2 V6
    Apr 2006
    HI there, I did a quick search but couldn't find an answer to this question.
    i'm running LPG Gas research carb set-up (yeah,yeah, BBQ etc) on an ecotec, pacey extractors + 2.5 exhaust and cold air intake. Just noticed on this forum that Mace produce a 12mm plennum insulator and a 25mm insulator. My question is what advantage is 25mm over 12mm? Extra tourque low down?
    Mar 2008
    Quote Originally Posted by immortality View Post
    Hey immortality,
    We'll be releasing a set of higher ratio rockers to suit very soon
    Steve
    Mar 2008
    Quote Originally Posted by Col74 View Post
    Hey Col74,
    The 12mm manifold insulator give around 10% increase in low down torque, while the 25mm item give around 13% increase over a broader range.
    Steve
    SV62NV's Avatar
    SV62NV is offline Scuba Steve
    MY09 VE SV6
    Mar 2009
    Kurunjang
    hey steve just wondering with that cai for the vs that replaces the orginal air box, what type of gains are we looking at? just curious as i was thinking of getting one, cars a vs series 2 acclaim v6
    Thanks, Shane
    Mar 2008
    Quote Originally Posted by shaneomac000 View Post
    Thanks, Shane
    Hey Shane,
    In regards to gains you'd be looking at around the 5kw at the wheels mark+
    Steve
    SV62NV's Avatar
    MY09 VE SV6
    Mar 2009
    Kurunjang
    alright no worries thanks for that steve, gimme bout 2 weeks and ill order one off ya , to get one i just do a buy it now off ebay? btw ill prob come pick it up
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    hey steve, welcome to the forums,
    onto an area that hasnt been explored much yet, what happening in the way of alloytec modifications?
    i know you have the manifold spacers, but is there anything else on the design wall at the moment?
    cheers
    Andrew
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Mar 2008
    No a worry. In regards to purchasing the product we're easy
    Mar 2008
    Quote Originally Posted by andyman View Post
    cheers
    Andrew
    Hey Andrew,
    In regards to alloytec development the only thing else we have besides the manifold insulators is a replacement cold air intake to suit VZ commodores.
    There are a few areas to improve the alloytec that we'll be looking into however at the moment we have other developments that we need to finish off first
    Dan VS 231's Avatar
    Dan VS 231 is offline Ell Sixty Seven
    VY Calais L67
    Jun 2008
    Perth W.A.
    Gday Mace and welcome to JC. Recently I have been considering purchasing some spacers for my Ecotec. However I do want to keep the engine cover on and keep that below my strut brace. Im not sure of actual measurments but I would think that both in full size (25mm) would bring the height up a little far. If that is the case would it be better to go for one only in full size (Im leaning toward the plenum spacer) or both in the smaller versions?
    Having said that the gains that are mentioned wouldnt be so much in the kw as delivery of the power of the engine already. Am I right to think that and would the low end gains from the spacers be offset at any point in the powerband of the engine. I would like some more down low and a plenum spacer should apparently do that for me.
    Cheers for the reply in advance.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Mace, when your heads and rockers package comes out one day, what size extractors would yo recommend as i am going to install some soon, for example Pacemaker have 3 primary sizes option, 1 1/2. 1 5/8. or 1 3/4 ? Qouls 1.5 be sufficient ?
    Mar 2008
    Quote Originally Posted by Dan VS 231 View Post
    Hi Dan,
    Thanks for warm welcome
    In regards to the spacers given that you have a VS and still want to keep the engine cover, from experience you’ll only be able to install a single 12mm spacer, in which case would recommend the 12mm manifold insulator. In saying this though it would be best if you measured how much spacer you have because strut tower brace designs vary, in which case you may even be able to fit a 25mm manifold insulator. If you had even more room then a 12mm plenum spacer works well. If you were running boost then I would recommend the 25mm item.
    In regards to power gains you’d be looking at a fair amount down low (hence the 10-13% increase in torque) plus a small increase top end. We have not found a reduction in power with the spacers fitted only gains across the board, hence the reason why we’ve found them to knock off around .2 to .3 seconds of the 1/4 mile time. If you have any more questions please don't hesitate to ask.
    Steve
  15. #15
    Mar 2008
    Quote Originally Posted by vxcalais_01 View Post
    Hey vxcalais_01,
    If you don't intend on going down the boost path anytime soon I would recommend the 1 5/8 as they are a good all rounder, with respect to outright power and low end drivability
    Steve
  16. #16
    Jul 2006
    Quote Originally Posted by MACE View Post
    Hey Col74,
    Steve
    Mace,
    Col74 and I are both on LPG, do we need a retune(possibility of leaning) with the 12mm spacer ?
    Thanks.
    P.S I think these spacers for plenum and manifold would both help with some low down lost from bigger exhausts/extractors etc.....
  17. #17
    Mar 2008
    Mace,
    Thanks.
    We recommend they to, as every car is different, however in many cases they don't. These spacers work on even a dead standard car and are more effective (noticeable) on the later model cars because they are usually heavier. In saying this though take either to the track (VS or VY) and you'll shave about .2 to .3 seconds off the 1/4 mile time from our own experience and feedback from other customers.
    Steve
  18. #18
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    hey steve how u goin? the spacers are goin great mate and im lovin the extra kick down low!! im interested in COLD AIR INTAKE ENCLOSURES for the vz also, do i need to drill or make holes? or will it slot into the original holes? if u could send me the fitting instructions that would be great thanxs scott
  19. #19
    Mar 2008
    Quote Originally Posted by Archers View Post
    Hey Scott,
    Just recovering at the moment after eating too many easter eggs LOL
    In regards to the alloytec enclosures there is no need to drill into the body work as they are a bolt on affair. Fitting instructions for this airbox will be written up sometime over the coming weeks.
    Steve
  20. #20
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    Hey Scott,
    Steve
    thanxs mate when u get the instructions done i will get a set off ya m8 thanxs scott
  21. #21
    Jul 2006
    Steve
    So would the 12mm spacer be better in this situation ?
  22. #22
    96 VS Executive S II
    Feb 2006
    Perth,WA
    Hi Mace - Welcome to JC -Hope To see you around for many moons to come =) I was just after a price on the Mass Air Flow Meters for 74mm and 85mm. If I am to order one how would I go about it - Thanks
    <insert something funny here>
  23. #23
    Mar 2008
    No probs Scott
    The 25mm manifold spacer offer's even more gains however it depends on your budget.
    Quote Originally Posted by RedGoesFaster97VS View Post
    Hey RedGoesFaster97VS,
    Thanks for the warm welcome
    In regards to pricing the 74mm MAF is $130 changeover while the 85mm item is $240 outright, including path loom. If you wanted to order one you can do it via email or over the phone.
    Steve
  24. #24
    Feb 2006
    Perth,WA
    Mace,
    Thanks for the info and quick reply, will get back to you on that one =)
  25. #25
    95 VS Executive
    Mar 2009
    hey mace.
    i am thinking of getting roller rockers and a cam
    and seen 1.9 rollers on ebay but said they are not good if you are upgrading ur cam.
    wat size do u recommend if getting a cam?
    or does it vary on what cam it is youre getting?
    cheers
    sl33per
    oh n how much for the ones u recommend??
    Quote Originally Posted by Hunter SS View Post
    you have to be careful though..... if you throw your rod in, you might only catch crabs
    >CJ<
    1995 VS Executive, VR Statesman interior, Police power!
  1. Huge Sale Vn Calais - Vs Parts Stato Parts Etc Etc Heaps Of Stuff
    By petezor in forum Parts And Other Items For Sale
    Last Post: 02-03-2008, 04:48 PM
  2. Wrecking VN - Selling all parts! Includes parts from later models others non-standard
    By DavidPartay in forum Parts And Other Items For Sale
    Last Post: 27-07-2006, 11:35 AM
  3. New Peformance Cam, Pistons And Parts
    By Supercharged_up in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-06-2006, 09:39 AM
  4. Peformance Chips?? Sport Chips?
    By jeffarido in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-08-2005, 08:12 PM
