thanks for the reply Steve
Hi Steve
I am wishing to do the 10PSI upgrade to my pulley.... Finally. I already have a pulley and i am wondering how much it is for the Hire of the Pulley removal and install tool. If you could PM me some detail inc payment i will process it.![]()
Hey S.T.K.E,
To hire the tool check out the link below.
Pulley Removal Tool - MACE ENGINEERING GROUP
Steve
Although I am a bit picky it does say pulley removal tool.... does that also include the installation tool as well?
Good question
We've changed it such that it clearly states that it does both jobs
Pulley Removal And Installation Tool - MACE ENGINEERING GROUP
Steve
Just ordered it now mate. hope to see it soon. Thanks for the answers to my quesitons
Not a worry S.T.K.E
we'll get this out to you ASAP
Steve
Thanks for the pulley tool worked a treat. Will send back Monday. Just to let you know the 8mm thread was stripped when we got it, so i made you up a new one.
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
Not a worry S.T.K.E, glad to hear you're happy with your new found boost
Steve
MaceEngineering
i am interested in the 10 psi upgrade and 1.9:1 ratio rockers this may well be accompanied by a full exhaust system of no more than 2 1/2 inch including extractors. what realistic power gains would i expect to gain from all this? cheers Adem.
Hey Adem,
Best bank for buck with these motors boost, rockers and cat back exhaust (no need for extractors unless you're going to do more mods) and a cold air intake will net gain of around 45kw at the rears! Bare in mind that a standard car makes around 110kw at the wheels. So you'll be very happy with these mods as it will transform the car
If you have any more questions please don't hesitate to ask
Steve
MaceEngineering
Im thinking about buying your 25mm spacer (COLD AIR INTAKE INSULATOR FOR HOLDEN SUPERCHARGED 6 L67), but noticed it'll lift my fuel rails up. Does the kit include adaptors to allow for this or do I do have to do something custom or look into new fuel rails?
Im just looking at way too cool down everything and thought of this mod n cold thermostat first
Hey ducker85,
The kit comes with everything needed for the job (including fuel rail extenders)
COLD AIR INTAKE 25MM INSULATOR KIT FOR HOLDEN SUPERCHARGED 6 L67 - Mace Engineering Group
We can also supply cooler thermostats to suit as well
If have any more questions please don't hesitate to ask.
Cheers,
Steve
MaceEngineering
are there mace parts available for the sv6 sidi ?
MaceEngineering
i am interested in purchasing 10psi pulley upgrade pack. i believe the price is $295.... does this include any sort of warranty? is it cheaper to pick up?
MaceEngineering
1. How much should standard mechanic charge to install pulley?
2. Are there any reasonably priced mechanics who have fitted pulleys on l67 before in melbourne if so who are they?
3. Do I still need to loan removal tool if a mechanic is to fit the item or do they have their own tools?
4. What is location for pickup?
5. Pm me with mayment details soon please.
Thanks![]()
About $80
Full Flight Engineering in Epping can do the installation work.
Most likely
Lalor
5. Pm me with payment details soon please.
Will do
If you have any more questions please don't hesitate to ask.
Steve
MaceEngineering
Hey,
What is the part number for the belt which comes with the 10psi pulley? Thanks
adz_vy,
The length that we would recommend would be a 6PK-1735. Being a standard sized belt you can get from pretty much any local automotive parts supplier like Repco etc.
Steve
MaceEngineering
Hey Steve,
I've currently got what i think is an FIT "10 psi"/87mm pulley on my L67 stroker, and atm its putting out about 6-7psi, with a 5% overdriven balancer. Im getting a mafless tune done on it soon, and was keen to actually get 10psi to keep me happy for a while. I've done some asking around and people seem to think an 82mm pulley should do the trick. My question is, will a smaller pulley from you guys fit on my alleged FIT hub ok? Or will i be able to remove the FIT hub with the pulley removing tool?
Thanks, Dan
