I've got a few questions regarding an airbox for a VN. My VN is running group a twin throttles and making around 310rwkw at the moment with a Hsv style over the radiator intake and Lower airbox also with a 3" hose from the front bar through the guard into the airbox via a hole in the bottom. I'm running a K&N panel filter and the group A top airbox section.
What I was thinking was running one of your airboxes modified to feed from the hsv style intake and 3" pipe through the guard of course, and also running a rather large pod filter.
So what I was wondering was two things. Firstly do you think the HSV style intake could be adapted easily enough? And secondly, could a 7" long pod filter with a 6.5" diameter base and 5" outlet be made to fit? And lastly, considering the angle of the group a intake Y piece, would the V6 item suit better?
“So what I was wondering was two things. Firstly do you think the HSV style intake could be adapted easily enough?”
It could, however I don’t think it would be worth while.
“And secondly, could a 7" long pod filter with a 6.5" diameter base and 5" outlet be made to fit? And lastly, considering the angle of the group a intake Y piece, would the V6 item suit better?”
It would be tight but I don’t think it would be a problem fitted something similar in the past except it was 9” long
On another note we may have a plenum spacer to suit the factory GPA manifolds over the coming months, to assist with improving air distribution between cylinders
If you have any more questions please don’t hesitate to ask.
Cheers,
Steve
MACE Engineering Group
www.maceengineering.com.au
Powering Australia's best Commodores
Find us on Facebook:
MaceEngineering
So how much for an airbox to suit without the supplied filter?
MaceEngineering
Hey Steve, I got a quote of you last time but can't find it. Would like the CAI & 70MM TB for a VR V8. Could you give me a price including postage to 3029. And how can I make payment ? Thanks
Muss![]()
MaceEngineering
Hey steve,
I purchased a CAI & 70MM TB off you for my VR V8 and all I can say is F*#N AMAZING! Didnt take me long at all to put everything on and as soon as I took it for a test I could feel the throttle response to be alot better and when I put the foot down the car has a real old school grunt to it ! Sounds awesome. I couldnt be more happier money well spent I have to say. Anyone looking to get more out of their V8 without doing heads & cam package. I HIGHLY recommend this mod. Thanks again Steve. I will definitely be doing more business with MACE ! Great Customer Service and Great quality Products.
Muss
CHECK OUT MY VR CALAIS
http://forums.justcommodores.com.au/...lais-5-0l.html
MaceEngineering
Our off the shelf universal CAI kit (with no filter or piping holes pre cut) fitted on a 383 stroker with COME racing manifold and custom 4 inch snorkel, with and without lid
MaceEngineering
Hey how much are the 1.9 rockers for ls1?
cheers,
Blair.
Hey Blair
The price for the rockers are shown in the link below
HIGH RATIO ROLLER ROCKERS TO SUIT VT-VZ LS1-LS2 V8'S - Mace Engineering Group
If you have any more questions please don't hesitate to ask.
Kindest Regards,
Steve
MaceEngineering
Or for $300 buy Sean's cam.
Cheap, fast, reliable.....you only get to choose two.
My daughter has a 355 stroker in her VT Clubby. It is having idling issues, and was wondering if a 70mm throttle body may help.
It is running a mild cam, and stock heads, HSV extractors, and Auspac twin 2.5" exhaust.
It has heaps of grunt, but just doesnt idle as smooth as it could. Its not the cam. Seems to need more air at idle.
Do you do a throttle body for the VT Holden motor, and how much? Thanks, Ian.
MaceEngineering
Thanks Steve, will find out the cam specs.
Excellent![]()
MaceEngineering
To be clear for us to suggest that a larger throttle body would solve idling issues would be very premature, if anything the seal on our throttle bodies can be better then from factory so it would likely make the problem worse not better, hence my answer to the question
Sure cracking open or drilling a hole in the butterfly are effectively zero cost solutions, it may also be masking the underlying problem/trait of the setup, which isn't a good idea
MaceEngineering
What he said ^
so its 190$ for the 70mm throttle body if a standard 5l throttle body is sent in for you to bore out?
or have i read that wrong ('changover' price)
MaceEngineering
Hi Steve,
Just wondering what you would recommend for upgrades on a budget?
will be going mafless with otr down the track, but at the moment with a limited budget, just wanna see what you recommend.
Have up to $1000 to play with at the moment. i know it aint much, but with a new bub on the way funds for my toy are
few and far between lol.
oops, forgot to say that the car is completely stock, and is a series 2 Vx ss. only thing done is NGK platinum plugs and MSD leads
cheers
David
To be honest, I would recommend Cold air intake, Exhaust and tune.
We can supply with an OTR, as shown below, and an mail order mafless tune (changeover) for $975 delivered
Alloy OTR Cold Air Intake To Suit Holden VT - VZ V8 - Mace Engineering Group
Other options to consider would be our 1.9 high ratio rockers (up from 1.7) and a 25% under driven harmonic balancer which the V8's respond to very well. Please see
VT II - VE GEN IV BALANCERS - Mace Engineering Group
Please don't hesitate to ask if you have any more questions.
Bart
MaceEngineering
thanks bart
i think i will go the otr package. sounds pretty good to me. what likely power increase should i get from that? i have heard mixed responses. some people paying 10-20rwkw, others saying anywhere from 30-50rwkw. its my first v8 so a lot of this stuff is new to me.
do you also sell diff gears, i was looking at buying clubby diff gears. i probably sound like a real dumb ass right now, lol but like i said this is my first v8. and i have never really modded a car to much before.
cheers
David
Hi David,
"i think i will go the otr package. sounds pretty good to me. what likely power increase should i get from that? i have heard mixed responses. some people paying 10-20rwkw, others saying anywhere from 30-50rwkw. its my first v8 so a lot of this stuff is new to me. "
10-20rwkw would be a good figure to work with, some people claim huge numbers but generally there would be other mods that would contribute to that figure. OTR's are also more efficient on the open road when heat soak isn't a problem like when your stuck in traffic in the middle of town.
"do you also sell diff gears, i was looking at buying clubby diff gears. i probably sound like a real dumb ass right now, lol but like i said this is my first v8. and i have never really modded a car to much before. "
Unfortunately we don't. You can try Holmart for brand new gears or contact your local diff shop who may be able to supply 2nd hand gear sets and install for you.
Bart
MaceEngineering
