+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 70
Thread: 3.0 litre V6 for the Commodore
    Sphinx's Avatar
    Sphinx is offline O.G. Sphinx Berlina
    VX Calais II LS1
    Aug 2005
    Pakky
    Default 3.0 litre V6 for the Commodore
    Commodore to get 3.0-litre V6 - www.drive.com.au
    I reckon it'll be the 3.0 DI LF1 which is 190Kw.
    Attached Thumbnails Attached Thumbnails 3.0 litre V6 for the Commodore-x10pt_6c003.jpg
    The Calais
    Sleeper Club
    Cursed CX8 is offline Banned Cursed CX8 Monaro Cursed CX8 Monaro
    VY Adventra
    Feb 2008
    Walking distance to FG meets
    Sphinx's Avatar
    VX Calais II LS1
    Aug 2005
    Pakky
    if you can get almost as much power out of a 3 litre then go for it. DI make a big difference.
    The Calais
    Sleeper Club
    VY Adventra
    Feb 2008
    di is really good, the 3.6di used in over sears by gm is making 220kw i believe
    VP Executive R-spec
    Jan 2005
    Well if you are going to build big slugs you may as well make one that doesn't use so much fuel
    Sphinx's Avatar
    VX Calais II LS1
    Aug 2005
    Pakky
    they're using the 3.6 litre version in the 2010 camaro and it's good for 305HP. Not bad for a 6.
    Caddy will have this lineup so hopefully Holden get that LLT motor. http://caddyinfo.ipbhost.com/index.php?showtopic=21505
    The Calais
    Sleeper Club
    Morton's Avatar
    Morton is offline For external use only Morton W427 Morton W427 Morton W427 Morton W427
    Fairstar the Funship
    May 2006
    In addition to a more efficient motor, Holden REALLY need to look at making a lighter car
    The 1972 HQ Kingswood
    Jun 2005
    Quote Originally Posted by Morton View Post
    attention holden management. hire this man ^^
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    VE Berlina International II
    Nov 2003
    Interesting, same power, less fuel, me likey
    Thats all right, thats ok, I drive a commodore anyway!!!!
    VrWagz1's Avatar
    VrWagz1 is offline The Wagon on Wheels.. VrWagz1 Monaro VrWagz1 Monaro
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    too bad if i wanted to fit a set of extractors to that motor
    Reaper
    Grennan's Avatar
    Grennan is offline Justice League Grennan Senator Grennan Senator Grennan Senator
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
    FG XR6T Ute manual
    May 2007
    Brissy
    Quote Originally Posted by Grennan View Post
    I dare say the filter also looks like its an awkward spot to.
    Why in gods name would they go back to that style of filter when the current v6 has a cartridge type mounted on the side/top area of the passenger head just under the engine cover. So bloody easy to change, no more than 1 minute if you know what a socket is
    Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
    Sphinx's Avatar
    VX Calais II LS1
    Aug 2005
    Pakky
    here's the 3.6 litre version rated at 227kw. read that this motor uses a cartridge style filter that looks like it's a little lower than the one on the 3.0 litre.
    Attached Thumbnails Attached Thumbnails 3.0 litre V6 for the Commodore-llt-di.jpg
    The Calais
    Sleeper Club
    VY Adventra
    Feb 2008
  15. #15
    FG XR6T Ute manual
    May 2007
    Brissy
    Quote Originally Posted by Sphinx View Post
    Its in the same place as our v6's which is a higher than the 1 on the 3L
  16. #16
    revv_head's Avatar
    revv_head is offline I DRIVE A V6 SS :P revv_head Executive
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
    GROSS
    There is no replacement for displacement . I have only ever owned two cars. One is 5Litres other is 3.8Litres. :P
    I own an Commodore, therefore, I own the road
    Oh how i love rear wheel drive
  17. #17
    .:Brad:.'s Avatar
    .:Brad:. is offline Tukin 18s .:Brad:. Executive
    VZ wagon executive
    Apr 2009
    the Norhtern Beaches of sydney
    if it puts out the same amount of power and uses less fuel then i cant see many disadvantages........or maybe im not looking close enough
  18. #18
    FG XR6T Ute manual
    May 2007
    Brissy
    The way i see it going from the ecotec to the alloytec you needed alot more revs to go places do dropping engine sizes again regardless of di in such a fat assed car is going to need even more revs. Not terribly smart
  19. #19
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon andyman Senator andyman Senator andyman Senator
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    that LLT motor is a basic copy of what the vz/ve use, although the heads and inlet manifold are different to accommodate the DI they make 227kw and 367nm? on 87 octane fuel, with an economy of around 9.2L 100km
    that 3.0 motor is an alloytec derivative but is suited to fwd, so i doubt that will be used in the commo as it is staying rwd for much longer
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  20. #20
    FG XR6T Ute manual
    May 2007
    Brissy
    I wouldn't have a problem with them using the 3.6di donk because it would totally shit all over previous holden 6's, if they go with the 3ltr that would be gay
  21. #21
    revv_head's Avatar
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
    Smaller the engine is the gayer it sounds usually. But totally in terms of grunt I mean. Rotarys sound mad but nothing like a V8.
    Quote Originally Posted by .:Brad:. View Post
    Brad, even if it puts out the same amount of power it would inherently put out less torque. This issue hasn't been mentioned yet.
  22. #22
    revv_head's Avatar
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
  23. #23
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by revv_head View Post
    no not at all, look at all those german diesel's etc, yes i know different power characteristics but, 1.9-2.0L motors are putting out 320+nm of torque, more than the current commodores
  24. #24
    revv_head's Avatar
    VY-SII Commodore S
    Mar 2009
    Sydney, NSW
    Quote Originally Posted by andyman View Post
    But Holden is australian and it would be the same technology we are currently seeing? And as you stated it's a petrol engine not a diesel so it's not exactly in the same league .
  25. #25
    FG XR6T Ute manual
    May 2007
    Brissy
    i prefer the sound of the vw vr6 motors to any holden 6 and they range from 2.8 to 3.6ltr
+ Reply to Thread
  1. what oil for my 5 litre
    By franks v8 man ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-08-2008, 08:20 PM
  2. Vs 5 litre
    Last Post: 31-08-2008, 05:35 PM
  3. my 5 litre vk
    By les82 in forum VB - VC - VH - VK
    Last Post: 15-02-2008, 11:17 AM
  4. $1.40 a litre
    By s_pack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2005, 04:58 PM
  5. 7.0-litre Gen IV V8
    By daggett in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 31-03-2005, 01:23 PM
