if you snapped the key off in the ignition its just a matter of extracting the old broken key.. take it to a locksmith and if that was your last key double check they can make a newie for u, works out alot cheaper!
keep in mind only time to replace a barrel is when the tailpiece that activates your ignition switch breaks or the key tip stop (bottom of the key hole) is warn out, other than that they can simply strip it down and rebuild it, unless the barrel itself has be butchered!
