most parts available
white vn berlina with full electrics and mulbery trim
bronze vn executive manual with 160 thousand on the clock
vs bt1 v6 all parts are boxed
1990 mazda most parts available
willing to send only via aust post
hey where are you in WA?
Gen3 6spd Manual VT SS
VT V6 Manual turbo![]()
gday im in stoneville near mundaring
VN electric aerial mate?
it works just needs a new mast
Dam. That's all I needed lol. Mast and rope really...Works out cheaper and easier to just get another aerial and whack it in...no stuffing around.
Cheers anyway man.
no worries looked alright and then when i was unloading the car it fell off
How much for the manual gearbox mate?
power window module out of the berlina? how much?
IF SHE PLAYS STARFISH ILL PLAY SELFISH
also have a vr engine up for grabs just needs sum new gaskets for a fussy owner. and will soon have a full manual conversion for vn vp vr v6 as i have located a vr 8 blot flywheel
hey mate do you have the t700 auto speedo drive? the mechanical one with the cable?
i do on a gear box in the berlina . manual and auto ones will work if the gear box is shagged i will sell it to you
Do you have the strip that goes across the rear of the hood lining where it joins the rear windscreen?
yeah its on the side of the gearbox. I just need to make sure i get the one with the mechanical drive, so you can screw in a cable. Although i've heard the ones with the electronic sensor, you can just pull the sensor off and use a cable anyway?
Pics of the centre console from the Mazda? Is it the one with the console storage space?
alright here is sum randoms pics i got before the power failed. the first three at the mazda, followed by the vn berlina and then the vr engine
bumpski tyrtyrtr
vn tail lights in good nic how much
do you know if the heater core in the vn is any good? how much posted to 4051 (brisbane QLD)? cheers
