hey guys im sellin a crane cam that i purchased about 2 months ago, i brought it of a guy that installed it for roughly 3 weeks (1000kms) he reckons, an then a lifter failed on him so he romoved it.
the cam is pretty much brand new except for 1 loab where the lifter failed, ive had a quot done to get the loab re-grinded which was around 80 bucks and then it would be right to go again.
he's lost the specs sheet but ill try hunt up the specs on it if i get some interest.. he said its a mild cam with a power band from 3000-6000 and is an agressive cam with a choppy idle.. he brought it for $748.00 and im chasin $350 so its pretty much half price
give me a msg on 0412285069 if your keen and i can even send some pics if you would like
cheers..
bump.........
any one interested out there??
300 bucks anyone? ive also got the specs on it now!
Post the specs mate, I may be interested.
Voodoo Blue SSV M6 sedan
355rwkw
too easy mate ill post them up tonight when i get home
cheers
Hi Jaye, Cam card as requested. RegardsJim IoannidisCrane Technologies
--Forwarded Message Attachment--
PART
1449591
ENGINE TYPE:
HYDRAULIC ROLLER
SPECIAL
GRINDN
HR-224/3241-14 (Z-CAM)
ENGINE
1997-UP CHEVROLET V-8 LS1 5.7 LITRE
VORTEC 4.8L, 5.3L, 6.0L
VALVE SETTING:
.000
EXHAUS
.000
HOT
INTAKE @ CAM
3241
551
ROCKER ARM
INTAKE @ CAM
3241
551
1.70
ROCKER ARM
LIFT: EXHAUST @
ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER RATIOS
CAM TIMING
OPENS
CLOSES
ADVERTISED
.004
EXHAU
INTAK
29.0 BTDC
77.0 ABDC
286.0
TAPPET
LIFT
EXHAU
77.0 BBDC
29.0 ATDC
286.0
SPRING
RECOMMENDED RPM RANGE
WITH MATCHING COMPONENTS
TRIPLE DUAL OUTER INNER
PART
144833
MINIMUM
RPM
3000
LOAD
CLOSE
137
LBS @
1.800
O
1 51/64
MAXIMUM
RPM
6500
OPEN:
333
LBS @
1.270
VALVE
FLOAT
7100
CAM TIMING
OPENS
CLOSES
MAX LIFT
DURATIO
.050
INTAK
3.0 BTDC
41.0 ABDC
109
ATDC
224.0
TAPPET
LIFT
EXHAU
51.0 BBDC
(7.0) BTDC
119
BTDC
224.0
FIRING ORDER: 1-8-7-2-6-5-4-3
hope these help mate let me no what you think, cheers
bump..........
how about 200?
any people interested?
