ITEM: Custom Ecotec Plenum
CONDITION: New ...????...
PRICE: $500 egotiable
DELIVERY/PICK UP INFORMATION: Pick up or post
PAYMENT OPTIONS: Direct deposit cash on pick up
CONTACT DETAILS: PM or Post here
OTHER INFO: Custom made ecotec plenum suit n/a or turbo ,s/c. Made by a friend of mine whos changed to a twin setup for his twin turbo was made to suit his single turbo setup. Hasd a billet 80mm TB on it cost $280 alone. Front facing tb and is to suit Vt onwards LIM manifold could fit VS but has not been tested. Clears a bonnet on vt dont know about a vs but may be possible
Originally Posted by Smidy
hmm might be interested in this, as i was gunna get a reverse plenum for mine. got a few questions, in not mechanically minded so bare with me:
1) how do you bolt it on as the bolts for the normal plenum are reached by taking the plenum top off but it looks like it cant be taken off?
2) Does the fuel rail attach to this plenum the same as the standard one
3) Would anything else need to be modified to get this to work?
4) are the internal dimensions the same or bigger than the stock plenum?
Your mate probably knows what hes doing and wouldn't have created this if it were worse than the stock plenum/
-Smit
i would also like to know all of the above please.
You take off the Tb and do them up through there i hope you got small handsit clears alternator and thernostat so no need to move them
Yes it is a a standard base used so it mounts to rail the same
obviously your intake path is different that is the main things that needs modifying. Ideal if you wanted an OTRCIA maffless tune or something. Wiring for tps need to be extended a little. The throttle cable mount is different but uses stock cable and has a grub screw asetup to hook it up
It is larger volume than stock plenum though the increase isnt huge but makes a difference not only is it slightly larger volume but TB is 30% larger an has a better smooth flow through it
Any more questions just ask
Item is sold to smit thanks For the quick sale
