ITEM: VP V6 5 speed conversion, gearbox, tailshaft, flywheel, console cover, pedal box, gear stick and knob, floor cover, all bolts, wring loom and computer
CONDITION: good nick, changes fine and no bearing noise
PRICE: $500
DELIVERY/PICK UP INFORMATION: pick up or can help deliver
PAYMENT OPTIONS: cash
CONTACT DETAILS: PM , email ( rat095@hotmail.com) or phone 0439317141
OTHER INFO:
you still got this for sale mate? dont you need the conversion plate to bolt a manual flywheel on to a auto motor?
conversion plate? lol no mate i think you man be mixed up with the series 1 vn and series 2 vn / vp / vr and some vs. The flywheel on the series 1 vn is a 6 bolt compared to the 8 bolt on the other models i mentioned, if i inteded to convert a vp to manual using a series 1 vn setup, you would need a replacement 8 bolt flywheel, this sale is not the case though. A Manual conversion is basically a unbolt / bolt up job, no "conversion plate" needed.
Just wanting to add you dont need to sell the loom mate, just the computer, goodluck with sale, price is fair.
Other way around. ECU is the same auto and manual, and so are the tunes. Loom is different. Manual loom has a 2-wire connector for the reverse light switch instead of the 3-wire auto trans connector for converter lockup.etc. Auto loom isnt hard to modify but no need when you have the manual loom.
EDIT: Seems some tunes varied according to http://www.memcals.com/rcc_info_memcals.html.
ill have it off you then mate if its complete conversion, does it come with clutch/thrust bearing/ clutch cable etc aswell? got a VR ute i wouldnt mind converting to manual.
It does not say complete conversion man as for the flywheel bolts they are one use only as they stretch with tension when you do them up you can bye new ones from holden as for the spigot bearing they are a brass bush that tap in to the end of the crank it will be loss in the end of the crank if ya reuse it,
if ya dont wont to bye it stay the f#ck out of the tread man
where abouts are you mate i might come take it off your hands for that price.
if i was closer than adelaide i would have it..
