Got a LPG gas tank thats in date until december 2016
Was new in 2006.
Will fit in all commodore sedans VN to VX and possibly others as well, has the mounting brackets to secure it to the raised area in the rear of the boot
i live near Seymour and im often near the kyneton/bendigo area on weekends if its easier to meet that way.
$150
bump it up
still for sale!!!
bump to the top
Does it come with all the pipes and hoses and what not so it will all hook up?
Check out my VP
Wanted to Buy VP Front & Rear Bar/Bumpers
no just the tank, altho i do have the full LPG gas kit that will fit any V6 VN-VS that i took of my ute.. im selling that in a different listing.
how much would it be for both? and does it cost much to be installed?
Check out my VP
you could install it your self mate its pretty easy to do just a few gas lines and water lines and a bit of wiring. You can have the in date sedan gas tank and all the LPG gas kit for $300
you would need to get it certified after installation though.
Pretty easy to do that, they just check for leaks and that it works correctly, ie stops the gas flow when it stalls.
skunk gas is good, i can get over 400km from $40 of gas on the highway and the car is quieter.
Where does the gas pipe to refill the tank go? can it go to where the petrol cap is??
and does it come with the chip and anything else??
Also is there much power loss? and is it for duel fuel or straight gas?
Also What size is the tank?
How many ports does it have on the tank?
Check out my VP
the gas filler pipe can go where ever you want it to go, it would be duel fuel, what do you mean "the chip"? you dont loose bugger all power imo, the tank is 80 liter, dont know what you ment by ports on the tank? Do some research on LPG systems if your interested.
i was told there needs to be an ecu chip for it to work properly??
and i dunno about ports either, i was told to ask u about them, I am interested, just got to wait to see if i have enough cash to get it installed, so i can get the rebate from the government![]()
Check out my VP
nah no chip in the ecu needed at all.. it runs fine on the standard ecu.
sorry mate i really wanted this, but now cant afford it, run into other expenses...
if you still have it in a few months i may consider it again...
sorry for wasting your time
Check out my VP
