Results 1 to 1 of 1
Thread: alternator, shocks, manifold
    dons vs's Avatar
    dons vs is offline
    vs ute
    Sep 2008
    Default alternator, shocks, manifold
    I have a recoed alternator for a buike v6, i bought it in a hurry because i thought mine was stuffed only to realize the nut at the back was loose so no need for this now
    paid $120 will let it go for $100
    fresh reconditioned factory alternator has 6 months warranty as well i beleive.
    pair of pedders red strust for rear of either wagon or ute, they came with my vr ute but the holes at the bottom to bolt to the nuckle where to small for the stub on my nuckle so not sure if its right or now but all the bushes are in good nick and comes with washers and nuts ready to install, someone with a bit more knowlledge between models may know what they fit but im guessing its the live axel rear end ones but the bottom mounting hole is smaller than the monroes i have in there now.
    $50 the pair in good condition no damage or leaks.
    ecotech intake manifold, plenum, t/b, injectors, fuel rail and cover basically a manifold has been unbolted with everything still attached thats what i have, it needs a good clean up but apart from that there is no damage.
    Make an offer as im not sure what there really work im sure with the injectors in it still it should be worth something, there the blue injectors as well not sure if that helps either
    dvd player and screen, think the brand is aerion or something, was in the ute when i bought it but i dont need it so took it out, its a 2 peice system both taking up a single din each so you need 2 spare dins to run it, pretty easy to rig up and works quite well.
    the screen pops out and swivels around to face which ever direction you want.
    $350 take it away in good condition.
    rda front slotted rotors for vr commodore, brand new in box $80 the pair
    all items are for pick up in pakenham i will not be posting this stuff.
  1. [SA] F.S. KYB shocks & Pedder Sports Ryder shocks
    By GTP 85 in forum Parts And Other Items For Sale
    Last Post: 16-03-2009, 04:43 PM
  2. Alternator not charging, no alternator light
    By 5L fury in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2009, 05:55 PM
  3. What shocks?
    By BANKS in forum General
    Last Post: 01-08-2008, 10:02 PM
  4. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
