Results 1 to 6 of 6
Thread: FS: Black 202 + 4spd cheap
    6cylpwr is offline
    Pumkin chariot
    Oct 2008
    Default FS: Black 202 + 4spd + a few other parts
    ITEM: Black 202 from an 85 VK
    CONDITION: Used. Had leaking rocker cover gasket and front main, both have since been replaced aswell as a new harmonic balancer and brand new leads (not kidding about the leads...engine has only run about 2-3 mins tops since putting them on). Comes with a few spares aswell:
    - rochester varajet 2
    - mechanical fuel pump
    - the old leads (not much use...but you can take em anyway)
    - ahh...i think theres some more stuff down in the garage somewhere.
    PRICE: $70 Negotiable
    DELIVERY/PICK UP INFORMATION: Prefer pickup, but i can probably drop it off for you for some petrol money depending where you are.
    PAYMENT OPTIONS: Cash in hand or direct deposit only thanks.
    CONTACT DETAILS: PM or txt me on 0415055809. please don't call on weekdays i wont be able to answer.
    OTHER INFO: 184,364 kms
    PICTURES:
    please note: does not come with the holley 350 in the pictures. will come with the rochester varajet 2s...unless you wanna give me more money
    ITEM: 4spd manual conversion to suit 202 (except pedal box and clutch cable)
    CONDITION: Used. the usual weeping seals and gaskets, never had it out of 2nd as im putting a v6 in so getting the car going perfectly hasn't been too high a priority. 1st and 2nd were perfectly fine, as was reverse. i see no reason why 3rd or 4th would be any different.
    PRICE: $250 negotiable
    OTHER INFO: it is most of a conversion, but not all. what is included in the sale is:
    - 4spd gearbox
    - flywheel
    - old clutch plate, pressure plate and thrust bearing if you really want them
    - tail shaft to suit a salisbury
    - gearbox crossmember and rubber mount
    - viewing plate
    - can also supply a manual shifter plate if you like (is from a vl, should still fit tho)
    - all necessary nuts and bolts (pressure plate to flywheel x4, flywheel to crank x6, mount to crossmember x2, crossmember to chassis x2, bellhousing to block and viewing plate x9)
    - if theres anything else i havnt mentioned here that you will need, just ask and ill let you know if it comes with the conversion.
    PICTURES:
    ITEM: vk carby est module computer thing
    CONDITION: works. never had any problems with it, but i didnt use the car that much.
    PRICE: $20
    OTHER INFO: N/A
    if theres a particular part you need, let me know and ill see if i have it available.
    Last edited by 6cylpwr; 14-11-2009 at 09:51 AM. Reason: price change + added more parts + pics
    Quote Originally Posted by STEALTHY™ View Post
    It could have had a boeing 747 engine too (assuming all the VL wankers havn't snapped them all up)
    rompVR is offline cranky202
    vc commy
    Mar 2009
    canberra
    Pumkin chariot
    Oct 2008
    Quote Originally Posted by rompVR View Post
    hey mate just wondering if this is still for sale
    yea, sure is.
    Pumkin chariot
    Oct 2008
    more parts added and prices updated
    Pumkin chariot
    Oct 2008
    bump bump bump
    Pumkin chariot
    Oct 2008
    bumpety bump
  1. cheap black 202 mod
    By VKCOMMO in forum Straight 6 Development And Modification
    Last Post: 18-09-2009, 08:57 AM
  2. [NSW] FS: LG Choc Phone. Black touch screen in good nick. Cheap
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 27-04-2009, 06:49 PM
  3. [VIC] Cheap black vs sedan 9 months reg
    By oyamum in forum Vehicles For Sale
    Last Post: 01-01-2009, 07:59 PM
  4. 4spd box for black motor
    By VKNutt in forum Straight 6 Development And Modification
    Last Post: 06-01-2008, 09:56 AM
  5. Black VZ monaro Stlyle Front Bar CHEAP!
    By buzurk in forum Parts And Other Items For Sale
    Last Post: 15-11-2006, 03:45 PM
