Hey guys
I am selling my T Trim setup on my car. It is a complete Bolt on setup for a Holden V8 EFI motor. Details as Below, what it comes with etc.
  • V2 T-Trim unit Polished and Detailed with blower Air assist with 90 degree outlet
  • 50mm Gilmer tooth cut 14psi pulley kit with tensioner
  • Crank pulley with all bolts
  • Precision parts full steel harmonic balancer
  • Braided oil supply line and oil pump fittings
  • Braided air assist line
  • Return line to sump
  • Chromed bracket
  • All bolts included, those are polished too.
  • Alternator
  • Siemans Deka 65lb fuel injectors
  • 4 inch core 600x300 intercooler
  • 3" mandrel bent Custom fabricated intercooler setup no shortcuts taken, polished piping.
  • Turbosmart silicone joiners
  • Turbosmart Megasonic Type-III bov
  • All high pressure clamps
  • Oil sump included (if buyer can wait for me to remove motor)
  • Wet element big pod filter
Bought it (brand new) last year August, Not to mention the epa's ive had with it so it was not used continously, also i only drive the car 3 times a month at the most.
Blower is capable of running 28-30psi
Intercooler setup is very convenient and efficient, all 3 pipes enter/exit through the 1 hole. Also running a massive pod behind the front bar.. (The one in my avatar is an old pic and the one i run now is 3 times bigger)
Making 471rwkw on my 355 with tyre slip at only 15 degrees timing..
Will take offers between $8,000 - $10,000 ($8,000 and above)
email me or call
ssn8r@bigpond.com or call 0435 249 005
