ITEM: LS1/Gen3 Bolt-in Oil control kit. Consisting of a Gate set and a large Aluminium directional top baffle.
The top baffle aids in the recovery of the oil by not allowing any oil to splash out during hard cornering, braking and acceleration. Oil recovery is essential if you're going to push your engine past its normal operating point.
The gate set is a bolt in unit that uses pre-existing holes in your LS1 Sump. The gates are a one way trapdoor, only allowing oil to flow towards the pick-up, and shutting when the oil try’s to flow away. Oil control is essential to stop cavitation and prevent your engine doing harm to itself.
CONDITION: Newly Fabricated
PRICE: $150
DELIVERY/PICK UP INFORMATION: Can courier anywhere in Aus. At buyers expense.
PAYMENT OPTIONS: Direct Deposit, Cash on Pick up
CONTACT DETAILS: aspecrace@optusnet.com.au, (03)8774-0343.
OTHER INFO: These are made for Gen3/LS1 engines pre VZ. i.e. VX/VY.
PICTURES: **Note Baffle and gate set not bolted down in pictures**
Gates in LS1 Sump
Gates around Pickup * Note Pick-up not supplyed
Pick-up with Top Baffle
Top Baffle in Sump
Optional LS1 Mesh Windage Tray Upgrade.
The mesh upgrade improves oil recovery further and will also decrease oil temperatures. Because of the Uni-directional mesh used, the tray will still protect the oil from crank windage. Recommended to be use in conjunction with the Bolt-in Kit.
Windage Tray Modification is strictly on a changeover basis
PRICE: $120 change over
Pictures:
Before Mod
After Mod
Thanks
Ben Potter
(ASR)
There is no such thing as stupid questions, Only stupid people.
Anybody Interested?
Oh BTW,
More than 1 of these is available.
Thanks
Ben
