ITEMS:
VN-VS Manual Pedal Box $80 Offers Welcome
VN-VS Clutch Cable $20
VN-VS V8 ignition module Working $80
VN V8 BT1 Instrement Cluster Reading 136xxx (Tacho Dash) $70 SOLD
VN Instrement cluster Surround $10
VN-VS Centre Console Complete With Auto Insert $20
VN Dash Pad Good Condition with no splits or cracks. $50
VN V8 Dash Wiring BCM Fuse Panel Complete (Goes Dwn engine bay Fuses And relays) $50
VP Front Bumper Reasonable Condition (White) $40
VP Rear Bumper Reasonable Condition (White) $40
VP door trims 3 of all Less Drivers Door $30
VP BT1 Ecu And Memcal $50
VR SS Fuel Tank And Pump (Pump Replaced 1000Kms Ago) $100
VR SS IRS LSD (Diff Only) $150
VR SS IRS LSD Double Shimmed (Diff Only) $250
VN-VS IRS Drive Shafts From Diff To Wheels With CV Joints $70ea
VR IRS Lower Control Arms Pair $50
VR SS Tail Shaft Suit Auto $50
VR-VS SS S Lower bumper Lip Set Front rear and sides $150 SOLD
VR-VS SS rear Bumper (gun metal grey) $100 SOLD
Solid rear end diff 3.89:1 gears and mini spool $300
Also have a vp Bt1 shell for sale No interior Motor Box Fuel Tank And Diff, Still Has V8 K Frame Suit Someone Needing A Body Lokking for $300 For shell Do HAve Complete Dash Will Consider All Offers
FEEL FREE TO MAKE OFFERS ON ANY OF THE ABOVE ITEMS
IF YOU REQUIRE ANYTHING NOT LISTED ASK AS I AM STRIPPING TWO CARS VRSS AND VP BT1
CONDITION: Used
PRICE: As Above
DELIVERY/PICK UP INFORMATION:
PAYMENT OPTIONS: COD, Direct Deposit
CONTACT DETAILS: Email, PM
PICTURES: Can Get If Needed
gday, i'm chasing a non abs/non vario high pressure and return steering hose for the v8.
apparently theres different steering hoses for regular steering cars compared with ABS and vario steering cars.
don't suppose you can help with these bits
do you have a good condition 5 speed gear knob?
Hi would you have the gear shifter rubber boot that goes on the manual plate and gear shifter?
Hitman Sorry I do But Keeping For Me Senator Sorry
Mitch Same As Above Got it But Am Keeping Sorry
Will separate diff from vp its solid live axle 3.89:1 gears and mini spool $250
G'day mate,
do you still have the dash cluster,and if so would you post to Melbourne.
Paul 0431566009
Are you talking about , like the lower lip that go on the vs s's?
good condition ? any pics?
plastic or fibre glass
Yes The Lower Bumper Lip Set as seen on vr ss and s And vs ss and s
this is a genuine kit off a white ss i have sold as a kit
BUT have one Left on my car would rather not part with it but for the right price i will sell..
i also can supply fog light bumper inserts and fog lighs and brackets ****one fog light is brocken and also plastic bracket is broken bracket is an easy fix just tech screw a peice of alloy across crack as for the fog light buyer would have to sorce****
Bump
still open to offers
To The Top
Bumpman you forgot you pull my module off:P
