Results 1 to 6 of 6
Thread: Snap On Cushion Grip 1/4 Die Grinder & Burr As New
    Vr929 is offline
    Vr S2 Calais
    Jan 2009
    Default Snap On Cushion Grip 1/4 Die Grinder & Burr As New PICS UP
    Hi All Up For Sale I Have A
    Snap On Cushion Grip 1/4 Die Grinder 25000rpm it has only been used once and that was on Tuesday for about 10 minutes up at Queensland as i bought it to use it on a mates truck but only used it for 10 minutes and now have no use for it as it wont come in handy any more for me. It has a few scratches on it but this doesn't influence it at all. it also comes with a Snap On Tungsten Tip which cost me $110 as it is for steel and aluminum. The Die Grinder Will come With a new Nito & Ryco Fitting also will come with a 60mm grinding wheel which retails for over $35 dollars.I purchased it off the Snap On Truck for $250 so all up this set up cost around $385 I'm Wanting $280 ONO. If You Have Any Question Please Send Me A Message and i will Answer it ASAP Or Contact Me or SMS on 0403800737 PLEASE NO COMPLAINERS
    PLEASE READ
    ITEM COMES from smoke free and pet free home
    Specs
    Die Grinder, Air, Mini, Cushion Grip, 1/4" Collet (25,000 RPM)
    Features:
    PT Series Features:
    • Tackle virtually all material removal jobs with ease and professional results.
    • Ergonomic style handle is molded and contoured to comfortably fit the hand. Helps to absorb vibration while insulating against the cold.
    • Adjustable rear exhaust outlet allows adjustment of exhaust away from the work area while keeping material removal away from operator's face.
    • Thermally balanced air motor acts as internal cooling system to protect moving parts. Efficiently routes air to control surface temperature of tool. Reduces motor vibration and collet runout.
    • Built in 10 position power/speed regulator precisely matches tool speed to job requirements.
    • Easy bit changing using standard wrenches.
    • Safety style variable speed paddle trigger helps prevent accidental starting of tool.
    • Simple modular design allows for ease of service
    • Low dBA rating reduces fatigue from noise.
    Product Specifications
    Stock # PT100
    Name Die Grinder, Air, Mini, Cushion Grip, 1/4" Collet (25,000 RPM)
    Description Mini Die Grinder
    Recommended Air Pressure, psig (kPa) 90 (620)
    Air Consumption, free speed, cfm (scfm) [l/min] 1.57 (10.4) [44.46]
    Air Consumption, working, cfm (scfm) [l/min] 1.4 (9) [39.64]
    Horsepower, HP .25
    Free Speed, RPM 25000
    Sound Level, free speed, dBa 85
    Sound Level, working, dBa 84
    Air Inlet Thread Size 1/4"-18 NPT
    Recommended Hose Size, inches (mm) 1/4 (6.35) ID Min.
    Collet Size, inches 1/4
    Overall Length, inches (mm) 5.87 (149)
    custom vk Calais
    Jan 2009
    Vr S2 Calais
    Jan 2009
    Vr S2 Calais
    Jan 2009
    Default Snap On Cushion Grip 1/4 Die Grinder &Burr As New
    Images of the die grinder has a few scratches on the black body but in new condtion only used for 10 minutes
    Attached Thumbnails Attached Thumbnails Snap On Cushion Grip 1/4 Die Grinder & Burr As New-05102009.jpg   Snap On Cushion Grip 1/4 Die Grinder & Burr As New-05102009_001.jpg   Snap On Cushion Grip 1/4 Die Grinder & Burr As New-05102009_002.jpg   Snap On Cushion Grip 1/4 Die Grinder & Burr As New-05102009_003.jpg   Snap On Cushion Grip 1/4 Die Grinder & Burr As New-05102009_004.jpg   Snap On Cushion Grip 1/4 Die Grinder & Burr As New-05102009_005.jpg
    Vr S2 Calais
    Jan 2009
    Vr S2 Calais
    Jan 2009
    sold please remove
  1. Commodore Seat Cushion Changing
    By Stretcher Bearer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2010, 06:23 PM
  2. [NSW] leather handbrake grip
    By POVRTY in forum Parts And Other Items For Sale
    Last Post: 13-03-2009, 07:00 AM
  3. new leather hand brake grip
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-09-2008, 04:57 PM
  4. How do you change a VR/VS auto gear-stick grip?
    By joe_rolls_commo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-05-2008, 09:28 PM
  5. Snap
    By StatOmaN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2006, 05:06 PM
