Results 1 to 6 of 6
Thread: FS: Big Port L98 Manifold
    Jecs's Avatar
    Jecs is online now PAVTEK Race Engines
    '97 Caprice 355ci & Mongoose Shield Pushy
    Feb 2005
    Default FS: Big Port L98 Manifold
    ITEM: Big Port L98 Manifold
    CONDITION: New
    PRICE: $1000
    DELIVERY/PICK UP INFORMATION:
    PAYMENT OPTIONS: COD or Direct Deposit
    CONTACT DETAILS: Andrew - 0409 970 092 or PM
    OTHER INFO: Big Port L98 Manifold from Z07 Corvette Motor. Brand New with 36lb Injectors & Fuel Rail. Fits under bonnet looks Factory (less cop attention) will Fit to LS1 with slight modification. Mates Running The Same Manifold on his VY Clubsport with Heads and Cam It Made 300rwkw & With This Set-Up Made an Extra 30rwkw Bringing it to 330rwkw. It is the perfect replacement manifold for anybody looking to achieve a simple gain over standard or the enthusiast who is building a 500hp Motor.
    PICTURES: Will Take Some When I Get A Chance.
    all those get judged by me, the king of kings..
    WHII Statesman
    Sep 2006
    Geelong, VIC
    Hold on a second there mate, theres a few mistakes in you decription.
    Can you please confirm if this is an L98 manifold, or an LS2 manifold?
    The L98 manifold you specify does not fit onto an LS1 engine. L98 manifolds suit L92 heads which are square port, compared to an LS1 manifold designed for cathedrel port heads. If it is an LS2 manifold, it will bolt onto an LS1.
    Also, I'm not sure what a Z07 corvette is, but I assume you mean a Corvette Z06 with an LS7 engine. If so, the LS7 is different again.
    Also, the injectors. Standard or aftermarket?
    Jecs's Avatar
    Feb 2005
    Quote Originally Posted by SirNemesis View Post
    it is a L98 manifold. it can be bolted up with slight modifications, it is not a straight bolt on job. and the ports are bigger, but a slight machine to the heads to match the ports on manifold will fix that and increase air flow. and i the injectors are standard to suit that motor.
    WHII Statesman
    Sep 2006
    Geelong, VIC
    L98 injectors are 39lb, and I cannot see how it is possible to machine the manifold or heads to suit without compromising the seal, as the LS1 ports are taller.
    Jecs's Avatar
    Feb 2005
    the owner of the VY Clubby used to work for Flowcraft, and is now a full time engine builder. hes got the exact same manifold on his car, running.
    if you are interested in the manifold, i can give you his number and you can get him to fit everything.
    Jecs's Avatar
    Feb 2005
    sold. lock thread
  1. should i port my box?
    By 10oxr in forum Car Audio
    Last Post: 25-02-2010, 02:09 PM
  2. [WA] ls1/ls6 port and polished manifold wih higgins 84mm throttle body
    By H1GHROLLR in forum Parts And Other Items For Sale
    Last Post: 20-10-2009, 07:04 PM
  3. [VIC] SWAP: Turbosmart V-Port BOV, for Turbosmart Plumb back or dual port
    By Wagon_Wheel in forum Swap / Wanted to Buy / Trade
    Last Post: 14-07-2009, 06:24 PM
  4. Port n Polish
    By Nzpure in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2008, 09:07 AM
  5. Inlet manifold-exhaust manifold cracked
    By aussieghostrider in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-06-2006, 10:23 PM
