Results 1 to 2 of 2
Thread: EOI: Genuine A8 VLT Motor REBUILT never started
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Default EOI: Genuine A8 VLT Motor REBUILT never started
    ITEM: Genuine A8 VL Turbo Motor out of a BT1
    CONDITION: AS NEW, REBUILT Never started
    PRICE: Negotiable, Make an offer, May swap for something to the same value of interest.
    ROUGH PRICE: $9,000
    DELIVERY/PICK UP INFORMATION: PICKUP Only, May deliver for a fee, see details below
    PAYMENT OPTIONS: CASH on pickup
    CONTACT DETAILS: PM, POST
    OTHER INFO: Please Read On FOR INFO
    PICTURES: AT BOTTOM OF PAGE
    HI ALL AND WELCOME!
    Here today I'm selling ALL of my turbo gear!
    DROP IN AND GO!
    This is a genuine A8 VL TURBO motor which came out of a BT1.
    I purchased this motor to rebuild! Which I have done.
    When Pulled down and inspected, it still had the factory X hones in the bore! Unusual for these types of motors which are hard to come by as it is. Not many around with the factory hone marks still left in them!!!
    The motor was rebuilt with the following parts:
    Piston were still like new so reused with brand new HASTINGS Rings
    The Crank was never removed so there was no need to change the mains bearings
    The Conrods were reattached to the crank via KING Bearings
    The Head is a RECO VLT head with a WADE CAM installed to it. It was then fitted to the bottom end with a GENUINE NISSAN Head Gasket and ARP HEAD STUDS
    Then it was time to fit the water pump, This is a ENDUROTEC Water Pump, Recommended by M&W Engine Builder's Located in Ballarat. (Also Purchased from them)
    Time for a GATES RACING TIMING BELT Fitted to the front, to ensure there was no problems with it
    Ok now for the rest, as thats just the engine!
    This listing will come with the following:
    Genuine A8 Turbo Motor REBUILT never started since
    Full 3" exhaust from the turbo back
    Custom High Mount Manifold with external gate
    External Gate is a Turbo Smart Ultragate 38mm with screamer pipe
    REBUILT T04E Turbo with internal gate welded shut, Oil and Water Cooled, Polished Front housing
    ALL oil and water lines INCLUDING Fittings
    Brand NEW never fitted Mirror Polished Forward Facing Plenum with semi polished XF Throttle Body Attached to the front
    Front Mount Intercooler With Piping to suit stock Intake manifold (can be modded to suit forward face Plenum) 3" inlet and outlet
    A heap of silicone joiners with some clamps
    Chrome Plumb back BOV (Blow off valve)
    Bosch 044 fuel pump, With Fittings (Hasn't had much use)
    A BRAND NEW 14mm O-RING Conversion BILLET Fuel rail in anozoied BLUE
    Twin Thermo's
    VL Alloy Radiator only had 2 weeks work
    Q45 Air Flow Meter 90mm 3 1/2" AFM Comes with plug
    Malpassi Fuel Regulator
    Oil Catch can
    Comes with an orginal BT1 VLT engine loom
    I do have currently on the motor a freshly painted wrinkle red holden rocker cover, but also have a nissan rocker cover there.
    I also have reciepts for this.
    YES its a genuine A8 motor.
    This is a serious listing only, please contact me if you have any questions as I have most likely to have left something out!
    CASH only on pickup
    PICK UP ONLY
    Located in MANSFIELD VICTORIA
    Can deliver for a fee and in a certain amount of distance, please contact if you are unsure
    PLEASE NO TYRE KICKERS
    NO POSTAGE
    I have uploaded some photo's will upload more when i get a chance, in the middle of moving so not much time on my hands
    The Pictures of the motor is in the build, i will get more pics later on when its all bolted together, This is just to give you an idea
    Nackerz's Avatar
    Jul 2009
    May swap!
    Also may swap polished plenum with semi polished xf throttle body and na runners that suit plenum for stock vlt plenum with cash my way
  1. rebuilt motor blown head gasket
    By aussie_macca in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-02-2010, 09:37 PM
  2. V8 Commodore Started motor on a HJ/HQ 253
    By nabed4t in forum General
    Last Post: 05-08-2008, 03:09 PM
  3. Rebuilt motor, blowing smoke from exhaust
    By frenchyvh in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-04-2007, 10:47 PM
  4. VN series II v6 motor and trans rebuilt, SA
    By churnit in forum Parts And Other Items For Sale
    Last Post: 09-09-2006, 03:55 PM
