ITEM: 355 stroker engine *sold pending payment*
CONDITION: Used
PRICE: $4000- or 5000 with torque power dual plane hi-rise and 1000cfm 4brl tb add $500 on both with new cam fitted!
DELIVERY/PICK UP INFORMATION: Buyer to organise
PAYMENT OPTIONS: COD, Direct Deposit, Funds Transfer or Other
CONTACT DETAILS: 0403024452
OTHER INFOelling my engine due to a few changes, it needs cam and lifters as i kept these! but i can supply new cam and lifters for $500 heaps spent on this engine, no shortcuts taken!! only done 3000kms since rebuild mostly dyno time made just shy of 500 hp with bigger injectors needed!
355 stroker, block de-dagged with a pollished vally and ported oil gallerys with zero deck, O-ringed with arp main studs, Pro-stroke 355 crank, Chev 5.7 steel I beams with capscrews & bushed small ends, ACL Race pistons with 10.5/1 comp with plasma rings, Pavteck mains girdle, Crane double springs, collets, retainers, Manley 2.06-1.60 stainless valves, ported and polished heads (550hp), Yella Terra adjustable roller rockers, High Energy sump modified for girdle, modified oil pick up, New water pump, Billet steel powerbond steel balancer,
PICTURES: [ATTACH]
[/ATTACH]
IF SHE PLAYS STARFISH ILL PLAY SELFISH
Sold pending payment!
BUMP!!!!!!! deal has fallen through![]()
s**t ! If only you were in Vic mate.
I can wrap it up put it on a pallet and freight it cheap through my work!?
BUMP....This is too cheap for whats done to it!!!
Was it originally a 308? from what car?
Can you send pics across to Daniel_d1981@yahoo.com.au and any other details about the engine
Thanks
Daniel
VH SL/E Blue on Silver
304 Conversion | Custom Headers | Trans-Go Shift Kit | 2800rpm stall | VL Turbo Diff | VL Turbo rear brakes | VT Twin Piston Front Calipers | VT Brake Booster | Slotted Discs F&R | Nolathane bushes.
hey mate sounds great! can you put up some pics? or email them to me
slats_92@hotmail.com
ill get some pics up tonight, was original 308! engine number starts VT***** from the VH series by memory?
Any Chance you would sell the manifold and TB seperate..
Why is it called Alcoholics Anonymous when the first thing you do is stand up and say, 'My name is Ray, and I am an alcoholic'?
yes i will separate!
bump! still up for grabs!!
I have sent you a PM a couple of weeks ago but still ne reply...
the manifold has been sold!
Price drop to $3000. Moving house so need it gone from the shed!
yeh mate no worries! ill proly go for a drive down that weekend and check a few out! i can throw a cam in it and stock 5l manifold if need be! anyway contact me on 0403024452 when your up!
sold!!!!!!!
