Results 1 to 3 of 3
Thread: vt bits, l67 fuel reg, throttle body,3inch exhaust rear section, TPS, hsv mufflers,
    wana s' charge stock vt is offline and have :)
    supercharged vt II acclaim
    Sep 2009
    goldcoast
    Default vt bits, l67 fuel reg, throttle body,3inch exhaust rear section, TPS, hsv mufflers,
    HI, just got some stuff lying around that dont really need that someone might find useful .
    ITEM: few random items, see below
    LOCATION- gold coast
    PRICE: see below
    DELIVERY/PICK UP INFORMATION: pick up gold coast, can send the smaller parts
    PAYMENT OPTIONS: , Direct Deposit, cash on pick up
    CONTACT DETAILS: PM, on JC
    OTHER INFO: see below
    PICTURES: if you interested in something let me know and will post a pic or 2.
    got a stock vt ECOTEC second hand throttle body. worked fine on my car. $20 SOLD SOLD
    TPS- works fine. $10 or throw in with throttle body. SOLD SOLD
    3inch rear exhaust section with factory looking oval tip. its twin 2.25 at the start(100mm0 then into 3inch straight thru, slips straight on the vt/x/y/z, hsv center sections SOLD SOLD SOLD
    GENUINE l67 supercharged v6 FUEL PRESSURE REG, works fine. thought mine was stuffed so got another one but wasnt the issue. $35
    2x 15'x6' black stocky's, tyres are gone $20 the pair.
    l67 SUPERCHARGED V6 ENGINE COVER- shells good, paints not so good. was white with chips in the paint, so i sprayed it with cheap silver paint. $20
    2xGENUINE HSV STRAIGHT THRU MUFFLERS. big hsv stamps. think there stainless, it did have 2.25' pipes on it but it looks a bit bigger on the inside of muffler so might be 2.5' internals. got 30-40mm of the 2.25 in exhaust on each end from where i cut it...... $60
    factory vt/x l67 center exhaust section, twin 2' into 2.25 at diff. has no leaks that i know of, pretty average cond, looks like rust bubbles starting on top of 1 muffler but not leaking, FREE
    pm me if ya keen on anything, cheers.
    edit- more bits
    set of v6 coils and dfi unit. off a vt.... had them on my super6 and didnt miss under 10psi of boost so would say there perfectly fine........ $40 3x coils + dfi
    2x single genuine l67 coils, no misses under load, both work fine. $50 each. will separate grab a spare while ya can theres not alot around and there $270+ per coil from holden..
    separate dfi unit- $10 SOLD SOLD SOLD
    Quote Originally Posted by chargedvx6 View Post
    I meant what I said and said what I meant so if you mean to say I said what you think I meant and it wasn't actually what I meant then that means you mistook what I originally said and meant to be wrong when in fact it isn't..
    my supercharged vt acclaim
    http://forums.justcommodores.com.au/...claim-l67.html
    Sep 2009
    goldcoast
    vt bits, l67 fuel reg, throttle body,3inch exhaust rear section, TPS, hsv mufflers,-040720101043.jpgvt bits, l67 fuel reg, throttle body,3inch exhaust rear section, TPS, hsv mufflers,-19052010940.jpgvt bits, l67 fuel reg, throttle body,3inch exhaust rear section, TPS, hsv mufflers,-040720101044.jpgvt bits, l67 fuel reg, throttle body,3inch exhaust rear section, TPS, hsv mufflers,-040720101045.jpg
    for arcarmody- the pic of the full exhaust is where it slips on too,
    can see the 2 dodgy bits i put on so it just sleved over my exhaust.(they're only tacked on with weld so can come off easy)
    Sep 2009
    goldcoast
    bump- few more things added...
  1. [SA] 304 manifold injectors injector rail and throttle body , 70mm throttle body suit v8
    By slywgn1 in forum Parts And Other Items For Sale
    Last Post: 10-06-2010, 08:42 PM
  2. Is It Safe to put oversized throttle body on VY with Dual Fuel??
    By cmacra10 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-10-2009, 05:00 PM
  3. FS Dual 3inch xforce exhaust
    By rathy1406 in forum Parts And Other Items For Sale
    Last Post: 29-05-2008, 09:35 AM
  4. This is My New 3inch exhaust
    By vt_ss_5l in forum VT - VX - VU - WH - V2
    Last Post: 13-10-2007, 11:26 PM
