ITEM: VN v8 auto trans parts.. Read list below.
CONDITION: Used
PRICE: As listed
DELIVERY/PICK UP INFORMATION: pick up or sent at your expense
PAYMENT OPTIONS: COD, Direct Deposit
CONTACT DETAILS: PM
OTHER INFO: ALL V8 PARTS
1990 VN v8 auto trans and crossmember. Removed as it was flaring the 1st to 2nd gear change slightly, only on full throttle though. on closer inspection on removal seemed the plastic kick down cable assembly on the trans was damaged so may have been causing the issue, looks to be replaceble- cheap $50
stock converter vgc- $30
auto trans selector assembly and floor plate etc- $20
auto flex plate- $20
tail shaft in vgc- $50
auto selector garnish plate- $20
more to come as i check back...
PICTURES: coming...
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
make an offer! need to get rid of this stuff
taking reasonable offers
Will the flexplate fit a VS series 1? If so, could you post a pic of it, is it in good condition? would you post to melbourne 3156 at my expense?
or better yet, could you tell me the part number and ill suss out whether its the same or not, which ever, your time will be much appreciated thanks.
still available
