Results 1 to 7 of 7
Thread: Nackerz Shed Cleanout....
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    Default Nackerz Shed Cleanout....
    Hey guys,
    Having a bit of a cleanout.....
    DELIVERY/PICK UP INFORMATION: Pickup, can frieght at your expense
    PAYMENT OPTIONS: COD, Direct Deposit, Funds Transfer
    CONTACT DETAILS: PM, Post or Email at vl_turbo@calaisturbo.com.au
    ITEM: N/A VL Auto Gearbox
    CONDITION: Used, In excellent condition with only 200 odd thousand K's
    PRICE: $250 NOW $200
    OTHER INFO:
    I have a N/A VL auto gearbox for sale. Came out of a running car, infact it's still in the car. Will be removed when sold or in the next couple of days. Keeping the cross member
    Has 200 odd thousand K's on it. Shifted well and smoothly.
    Auto
    Torque Convertor
    Flywheel and plate with flywheel bolts
    Tailshaft
    Trans Lines to radiator
    PICTURES: Yes, will get more when I remove the gearbox
    ITEM: N/A VL 25 spline drum brake sedan Diff
    PRICE: $150 NOW $100
    OTHER INFO:
    No Noises and in good condition. Still in car
    Pics: Not as yet
    ITEM: VL Complete Cruise Control Setup
    PRICE: $120 NOW $100
    OTHER INFO:
    Not sure if it's a factory cruise control, or an option as it was on a SL/Executive
    Will get photo's when I pull the gearbox out as it has a wire running to it...
    Complete with:
    Unit
    Cable to throttle
    All wires
    Purple Box where the wires come out of
    Switch for it
    And anything else that goes with it...
    Pics: Yeah a couple. Will get more though when I remove the gearbox as there is a wire still attached. Couple of pics before I removed the motor.
    Item:
    Lumpy camshaft. This suits 253, 308 or 304 with carby.
    It is a Hydraulic camshaft and here are the specs on it:
    Application and Basic RPM
    HYDRAULIC - Fair idle with lope, good mid range
    - upper RPM horsepower and torque. Good street
    and strip performance when used with correct
    intake, exhaust and gearing.
    BASIC RPM 2200-5400
    Cam Use
    Street/Strip
    Deg. Dur.
    @ .050”
    Cam Lift
    Int.
    Exh.
    224
    224
    Deg.
    Adv.
    Dur.
    Int.
    Exh.
    290
    290
    Deg. Lobe
    Separation
    110
    Running
    Clearance
    -Hot-
    Int.
    Exh.
    .000
    .000
    Gross
    Valve
    Lift
    Int.
    Exh.
    .496
    .496
    The cam is used, However it is in good condition
    Price: $100 NOW $80
    Pic:
    Item:
    308 STD size Flat top pistons with rods
    Used but in good condition
    Will post at your expense
    Price: $150 NOW $130
    Pics:
    Item:
    308 Standard Crank shaft. Removed to make way for the 355 stroker crank.
    Pickup, will freight at your cost
    Price: $100 NOW $50
    Sorry no pics of this as yet.
    ITEM: VL V8 4 Barrel Intake Manifold
    PRICE: $70 NOW $50
    OTHER INFO:
    Good condition, Very Little Corrosion
    Pics:
    ITEM: VL V8 Extractors
    CONDITION: Used
    PRICE: $100 NOW $90
    OTHER INFO:
    Good condition, Suit early style heads
    Pics:
    ITEM: Holley 650 Double Pumper Carby
    PRICE: $200 NOW $180
    OTHER INFO:
    Needs couple of things, Accelerator lingage and bolt in the top see pics
    Pics:
    ITEM: Torque convertor
    PRICE: $80 NOW $50
    OTHER INFO:
    came of an A8 vlt motor I brought. Someone has written windsor on it????
    Pics:
    Think thats all for now.....Will update as I go...
    Cheers Nackerz
    Nackerz's Avatar
    Jul 2009
    Ok guys, Here are some more pics of the gearbox, now removed...also comes with the cross member now as i dont need it..
    Also there is more of the cruise control setup~ Will get more photo's of it all together etc... Cheers
    Cruise Control
    Gearbox
    HJ premier
    Jun 2010
    Nackerz's Avatar
    Jul 2009
    Nackerz's Avatar
    Jul 2009
    Nackerz's Avatar
    Jul 2009
    Nackerz's Avatar
    Jul 2009
    Bump, all offers are being considered as I need the cash!
  1. [SA] Shed Cleanout - HQ,HJ,HZ,VN,VQ,VP,VR,VS
    By spirto in forum Parts And Other Items For Sale
    Last Post: 21-09-2010, 04:52 PM
  2. [VIC] Big shed cleanout all must go
    By CAMZVS in forum Parts And Other Items For Sale
    Last Post: 08-05-2010, 04:29 PM
  3. [VIC] Shed Cleanout
    By fatbats in forum Parts And Other Items For Sale
    Last Post: 08-02-2010, 08:55 PM
  4. [VIC] Shed Cleanout
    By DannyboyDS in forum Parts And Other Items For Sale
    Last Post: 04-11-2009, 03:38 PM
  5. [SA] Shed Cleanout
    By Renno in forum Parts And Other Items For Sale
    Last Post: 17-06-2009, 02:39 AM
