ITEM: 304 with forgies and tp manifold
CONDITION: New
PRICE: 3500 firm
DELIVERY/PICK UP INFORMATIONick up but may be able to arrange drop off within a few hundred k's for fuel money
PAYMENT OPTIONS: cash
CONTACT DETAILS: PM or 0405 205 371 george
OTHER INFO: need the cash fast so its got to go.
vr 304,factory clearanced for stroker zero deck height, 10.5:1 comp,30 thou over, arp main studs, speed pro forgies, a9l's with arp bolts, balanced, comes with rings and bearings (forget brand right now) has cam bearings installed
heads have been recoed but standard springs went in to keep them assembled.
comes with dizzy, fuel rails, balancer, timing case but needs sump and pick up , cam of your choice, t chain, w pump etc.
all work done by frankston engine centre
to get to this point the cost is 3500.
motor also comes with brand new torque power dual plane hi rise manifold never used , stainless bolts and arp washers, top vl rad hose, vl throttle cable, modified fuel rails that need finishing off, rocker covers (can supply some in atlas grey if you want) and a cvr throttle cable bracket
also got a new billet 1000cfm throttle body made by crd engineering (CRD Engineering - home) worth $770, very nice bit of gear looks better than others thats why i got this one.
can also supply a tune for a 286 done by electronic automotive for slightly extra if you need it.
all im asking for all this is $3500 firm so you basically get the manifold and t/b for free and save $1770
located in dandenong vic
0405 205 371 george
3500 for everything
300 extra for the tune
also have a set of vn heads that did 150k will part with those for 350
PICTURES: not at this point but can get them if really needed.
