Results 1 to 8 of 8
Thread: VS stuff - fresh reco gearbox, BCM, ECU, springs, handbrake setup, shifter assm, clus
    VPbomb is online now
    VE SS A6 Ute
    Aug 2005
    Default VS stuff - fresh reco gearbox, BCM, ECU, springs, handbrake setup, shifter assm, clus
    ITEM:
    Reconditioned VR VS 6HDD 4 speed Auto Gearbox trans - $650
    VS VR Holden handbrake lever assembly - SOLD
    VS VR complete shifter t-bar assembly auto - $50
    VS VR Dash cluster V6 - SOLD
    VS BCM hi - SOLD
    VS ECU - SOLD
    Key and barrel out of V6 Stateman (no key head) - $10
    VS VR IRS Whiteline REAR lowered springs - $40
    CONDITION: Used
    PRICE: See above.
    PICK UP INFORMATION: Macleod, 3105
    PAYMENT OPTIONS: Cash on pick up
    CONTACT DETAILS: PM
    OTHER INFO:
    VS V8 lowered progressive rate rear springs out of a Manual VS GTS. Has about 200km on them before I changed my spring to linear rate King springs and lowering further, so practically new. If you fit these, you will need lowered shocks as it will not trap these springs.
    Can supply picture of my old VS GTS just before these were removed.
    What’s listed on the tag attached to the spring:
    Whiteline c90-20061
    Batch – 645
    4L60E 4 Speed automatic gearbox out of a VS series 2 commodore.
    Bought this 2nd hand with the intention of putting in my ute to complete a full rebuild, but have recently sold my car.
    This transmission has 1500km on it since full overhaul (full rebuild by Central Automatics), so practically ran in. Has been sitting in a garage wrapped up for the past year. The transmission was built with towing in mind and contains heavy duty bands, clutches, heavy duty sungear, new shift solenoids, and new gasket/seal kit.
    Comes with the stall converter which is standard. Not sure if this was included in the original rebuild. The price in parts alone for just the rebuild is a lot more than the asking price. Unfortunetly I don't have the receipt for work done.
    Will also include new transmission mount.
    I was going to fit this to my 7HDD column shift ute before I sold it, so is possible... just need to change the selector shaft from the column shift auto.
    Complete shifter auto T-bar assembly from the VS Statesman in very good condition.
    Was going to use this for my Column shift to T-bat conversion in my VS V6 ute, but have since sold the vehicle.
    VS ECU - SOLD
    VS Hi BCM - SOLD
    PICTURES: Ask in thread and i'll post up for interested parties.
    VE SS A6 Ute
    Aug 2005
    Pictures added.
    Attached Thumbnails Attached Thumbnails VS stuff - fresh reco gearbox, BCM, ECU, springs, handbrake setup, shifter assm, clus-img_0369.jpg   VS stuff - fresh reco gearbox, BCM, ECU, springs, handbrake setup, shifter assm, clus-trans-pic1.jpg   VS stuff - fresh reco gearbox, BCM, ECU, springs, handbrake setup, shifter assm, clus-handbrake-vs.jpg   VS stuff - fresh reco gearbox, BCM, ECU, springs, handbrake setup, shifter assm, clus-bcm-ecu-key.jpg   VS stuff - fresh reco gearbox, BCM, ECU, springs, handbrake setup, shifter assm, clus-springs-vs.jpg   VS stuff - fresh reco gearbox, BCM, ECU, springs, handbrake setup, shifter assm, clus-springs-vs-side.jpg
    VX SS
    Jan 2009
    VE SS A6 Ute
    Aug 2005
    Quote Originally Posted by VS32 View Post
    Ill take the handbrake assembly, where bouts are ya?
    Macleod, 3105 (between Heidelberg and Greensborough). Sent PM with contact details.
    Cheers,
    Luke.
    VE SS A6 Ute
    Aug 2005
    Unhappy
    Updated list, refer to first post. More items added in post #8
    VT S2 Acclaim
    Nov 2008
    The springs, fitted to a VR Calais with IRS would it be above roadworthy height with 17"s on? If so I'm definitely interested
    VE SS A6 Ute
    Aug 2005
    Quote Originally Posted by pete_car View Post
    Pm replied to. Yes provided you dont have a big exhaust that's poorly fitted under the diff. Also not road worthy unless you have shortend shocks to trap the springs.
    Cheers,
    Luke.
    VE SS A6 Ute
    Aug 2005
    Still got some of this stuff left, refer to first post.
    Also have a few other things which I might start a new thread for, like;
    - customer sub box and Alpine amp to fit under the back tray of a VS Ute (hidden) with a port and porthole that come out behind the passenger seat (no cutting required) <- $300
    - Auto brake/accelerator pedal box <- $20
    - Clear tail lights off a VS Ute <- make an offer
    - Some front grey door trims in average condition <- make an offer
    - door wiring for electric windows <- make an offer
    - Centre grey console in average condition and has black stuff placed over where hand break and shifter goes as it was in a column shift ute, not sure of condition underneath it <- free
    - 1 VS Statesman rim with no centre and a RWC tyre <- make an offer
    - VS K&N air filter about 10,000 km old (these can be washed and re-oiled) <- make an offer
    - VS V6 top engine cover silver in okay condition. Few flakes off paint here and there <- make an offer
    - VS GTS stock front and rear stabeliser bars with nolathane bushes, not sure of size etc but can check if need be - $50
    - Fron VS grey bumper. From memory it's in good nick, maybe some scrapes (will have to check <- Make an offer
    Umm, think there is more crap but have to go and check. If you really really want pics, let me know and i'll try and get some over the weekend..
  1. [SA] Fs: Vy/vz leather shifter and handbrake
    By luminex in forum Parts And Other Items For Sale
    Last Post: 16-09-2009, 02:12 PM
  2. Handbrake Lever + Shifter
    By Josheh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2009, 05:29 PM
  3. Handbrake and shifter inserts
    By jesse3.8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2009, 10:35 AM
  4. handbrake and shifter
    By Archers in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 23-01-2009, 09:49 PM
  5. VS to VZ Shifter and Handbrake
    By GAMBLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2007, 11:14 PM
