It's time to start clearing the shed of some of the parts I've accumulated. I'll add things as I find them, and if you are after anything in particular just ask as I may have it (I have some drive belt tensioners, various bolts/brackets/pullies/belts to suit L67s etc)
Any item that can be posted will be sent registered post. Pickup is also fine.
ITEM: Autometer 2 1/16" gauges (Boost/Oil Pressure)
CONDITION: Used
PRICE: Boost: $70 | Oil Pressure $90 | Both: $150
DELIVERY/PICK UP INFORMATION: Will post at buyers expense
PAYMENT OPTIONS: Cash/Bank Transfer
CONTACT DETAILS: PM
OTHER INFO: Comes with what is in the picture. The oil pressure sender will be removed once the item has been sold and paid for.
PICTURES:
ITEM: 8PK1740 belt
CONDITION: Used
PRICE: $40
CONTACT DETAILS: PM
OTHER INFO: This was used with a 64mm pulley, YT intermedaite cooler, and an overdriven balancer. I'm only selling it because I am now using a larger pulley and it doesn't fit.
PICTURES:
ITEM: 6PK2345 belt
CONDITION: Used
PRICE: $15
CONTACT DETAILS: PM
OTHER INFO: This was used when I ran the alternator down where the A/C normally is
PICTURES:
ITEM: PFE Black -12 fittings (1 x straight and 1 x 90 degree)
CONDITION: Used
PRICE: Straight: $10 | 90 degree: $30 | Both: $35
CONTACT DETAILS: PM
OTHER INFO: These were used on my W2A res which I am no longer using.
PICTURES:
ITEM: L67 Rocker Covers
CONDITION: Used
PRICE: $20
CONTACT DETAILS: PM
OTHER INFO: No gaskets/bolts/cap, just the covers
PICTURES:
ITEM: 2 x 5/16" GM EFI Female adaptors
CONDITION: Used
PRICE: $20 each or $30 for both
CONTACT DETAILS: PM
OTHER INFO: These have had minimal use, I have decided to ditch the braided hose look and go back to standard rubber and therefore don't need them. More info can be found here: http://www.mscn.com.au/scripts/prodV...?idproduct=649
PICTURES:
ITEM: Speedflow fittings: 2 x straight -6 fittings, 1 x
CONDITION: Used (and are scratched as can be seen in the pics, but purely cosmetic)
PRICE: **SOLD**
CONTACT DETAILS: PM
OTHER INFO:
PICTURES:
ITEM: 2 x VS ABS Front Hubs (L & R)
CONDITION: Used
PRICE: Beer
DELIVERY/PICK UP INFORMATION: Pickup Only due to weight
CONTACT DETAILS: PM
OTHER INFO: Will only suit live axle cars (if you plan on using them on an ABS equipped car)
PICTURES:
ITEM: 2 x ecotec alternators
CONDITION: Used
PRICE: Beer
CONTACT DETAILS: PM
OTHER INFO: Both are NOT working and one has been pulled apart.
PICTURES:
ITEM: VS Statesman/Caprice electric seat switch (drivers side)
CONDITION: Used
PRICE: $15
CONTACT DETAILS: PM
OTHER INFO: This hasn't been tested (the car wasn't running when I grabbed it) but all the buttons feel like they should and all the pins are intact.
PICTURES:
ITEM: VS Statesman/Caprice door vent(drivers side)
CONDITION: Used
PRICE: $20
CONTACT DETAILS: PM
OTHER INFO: What you see is what you get.
PICTURES:
ITEM: VS V6 Cruise control module (including cable)
CONDITION: Used
PRICE: **SOLD**
CONTACT DETAILS: PM
OTHER INFO:
PICTURES:
ITEM: 2 x SS Difilippo cats (complete cat sections)
CONDITION: Used
PRICE: $130 each or $250 for both
CONTACT DETAILS: PM
OTHER INFO: The cats are stainless steel, the pipe that makes up the cat sections is a mix of stainless and mild and is 2 1/2". The extractor end has a 4 bolt flange to suit Difilippo extractors, and the other end has a 2 bolt flange. The pipes would suit a VS with Difilippo extractors, but can be modded to suit any car. One of the cats has a dent in it from being scraped on the driveway, but other then that they are in good condition. They are approx 900mm long
They were only on the car for a matter of months before I changed to ceramic cats to try and quiet down the exhaust (even with different ceramic cats and another muffler it was still too loud lol).
For what it's worth I paid $350 PER CAT when I got the system from Diflippo.
PICTURES:
They are a bit dusty and have a few cobwebs inside the pipe :P
ITEM: VS V6 Throttle Cable
CONDITION: Used
PRICE: **SOLD**
CONTACT DETAILS: PM
OTHER INFO: Removed from my Berlina. It is an ecotec cable, but I used it with the L67.
PICTURES:
ITEM: VS V6 exhaust (wagon)
CONDITION: Used
PRICE: Beer
CONTACT DETAILS: PM
OTHER INFO: Removed from a VS Wagon
PICTURES:
Bump. More items added
V6 wagon exhaust, its a stocky unit yeah? or is it an aftermarket/sports one? Cheers.
FORSALE - BRICKIES TRESTLES + SOLID STEEL SPIRAL STAIRCASE. -
http://forums.justcommodores.com.au/...ressively.html
Bump it up. SOme items have been sold, but still plenty left to go round :P
Bump, lots of items are on ebay (and more will be added).
Check it out:
tom02071988 | eBay
Bumping it up...
Rocker covers sold
