Results 1 to 2 of 2
Thread: VL turbo gear, trimatic, gt35, big fuel system, haltech etc 10sec setup
    cracker's Avatar
    cracker is offline
    Aug 2004
    Default VL turbo gear, trimatic, gt35, big fuel system, haltech etc 10sec setup
    CONDITION: Used
    PRICE: Firm
    DELIVERY/PICK UP INFORMATION: pick up would be dine, smaller items can be posted.
    PAYMENT OPTIONS: Direct Deposit cash on pick up
    CONTACT DETAILS: Email, PM, Phone or Other
    ITEM/S:
    Hotside
    Gt35 garrett ball bearing.
    .50 compressor housing, .82 turbine housing
    external gate.
    rebuilt by rotomaster 2 years ago, done approx 10 000km if that.
    no shaft play at all, no damage to compressor blades or turbine, always ran an air filter
    $1200
    All too suit low mounted gt35/40
    Braided feed to suit above turbo $35
    Hardline water fitting $25
    oil drain- $20
    braided/hardline water fitting $35
    braided actuator line, with boost controller
    all done in dash -4 fittings silver and blue
    $120
    turbosmart 38mm gate with screamer pipe
    vgc
    $350
    standard sytle turbo manifold with adpation to suit above mentioned turbo smart 38mm also has a 10mm spacer too suit gt35
    $150
    may done a package deal on the above.
    3" pacemaker pipe, some dints not to bad still works perfect $120
    full 3" catback exhaust with bashed out cat $250
    90deg intake pipe with pod filter 3" $40
    Chrome plated timing cover, top cover only. never been used, only installed once.
    $60
    Chrome plated engine removal hooks
    one that goes on the back near the oxygen sensor and the other that lives near the coil.
    $40
    chrome plated dip stick $15
    Trimactic 3 speed
    Fully manualised.
    one piece tail shaft
    3500rpm tce convertor
    b&m quick shifter with low mount box
    fully rebuilt by yarra vally autos less than 12months ago, actually hasnt even really been run in yet, done around 500km if that
    very strong box built with all the best bits too handle 350rwkw
    everything you need too convert your vl, bar speedo cable... was on the to do list
    also comes with an external oil cooler, davis craig. decent sizes lives under the battry area kina
    $3200 - cost me alot more then that and its basically never been used
    MSD blaster coil $80
    MSD A6LE i think.. $220
    haltech e6x
    custom loom too suit rb30 and have quite a few different base tunes to get you up and running.
    comes with 3 bar map sensor and usb to serial port convertor
    very good ecu, great plug your laptop in and your away.
    $1000
    Jd customs plenum, suit n/a runners
    polished with welds showing, comes with 68mm throttle body
    and ported n/a runners.
    vgc little use.
    $700
    no holes intercooler kit suit jd plenum and low mount turbo.
    mild steal pipe, 600x300x75 cooler
    $220
    Head has had some port work.
    just basic stuff by the looks
    crow valve springs
    wade 1147c camshaft
    and machined lifter blocks too suit
    less then 500km on the cam/lifter blocks
    lifters have been stripped down and cleaned.
    $450
    catch can, with breather built in the top.
    -6 braided line, fittings to suit standard thread on rocker cover.
    lives where the airbox would go.
    looks great, works well.
    $120
    fuel system gear
    built this as a massive overkill fuel system...
    twin bosch 044 pumps, 2L surge tank all braided line.
    check valves for each pump, pressure guage
    -6 fittings, 3/8 fuel lines.
    1000cc rochester injectors
    aeromotive fuel pressure reg
    all done less then 500km
    all mounted up on a piece of alloy
    includes relays and wiring for pumps.
    costs me a monster in braided line and fittings and countless trips to vpw.
    depending on interest will sell as a package.. although consider theres around $1200-$1500 in braided lines and fittings alone...
    ebay alloy radiator havent used it... comes with billet style radiator cap
    $180
    pm or email me at vlturbopower@hotmail.com
    will post more reasonable sized items...
    ie not the auto
    aust post limit is like 1m long and 25kgs or something along those lines.
    will prob think of loads of other things in the coming days... guess the cars for sale too... dunno how much though
    heres the link for pictures of the car as is basically, reason for sale driven it onces this year around the block...
    its a waste just sitting here and i want a jetski.
    spent all the cash on all the good bits in the past, no crap all in good working order i dont sell rubbish.
    cheers tom
    Aug 2004
    hot side set up all gone.
  1. [QLD] V6 turbo parts, turbo kit, fuel system, zorst, intercooler
    By harro_VR in forum Parts And Other Items For Sale
    Last Post: 05-04-2011, 11:51 PM
  2. [LS1] LS1 Turbo fuel system setup, help needed.
    By benjamino in forum LSx Development and Modification
    Last Post: 12-04-2010, 12:12 PM
  3. [VIC] V6 turbo setup, Gt35, built engine the lot!
    By cracker in forum Parts And Other Items For Sale
    Last Post: 08-03-2010, 07:17 PM
  4. Turbo system setup
    By Nackerz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-07-2009, 06:33 PM
  5. GROUP BUY TURBO - GENUINE GARRETT TURBO GT35/40R 700Bhp
    By GTS1963 in forum Parts And Other Items For Sale
    Last Post: 21-12-2006, 12:14 PM
